Durango DEX210 Thread >
Like Tree80Likes
Old 10-05-2013, 04:26 AM
  #12496
RC10Nick's Avatar
get yourself a good steering rack and a cf rear tower. I broke 3 towers before I bought my cf one. the stock steering rack is just a ticking time bomb. it will fail.
RC10Nick is offline
Old 10-05-2013, 07:21 AM
  #12497
8ight-e's Avatar
Trader Rating: 58 (100%+)
Kit comes w/ alum rack, the rtr does not. Two upgrades you must do are the aluminum rack and I would get aluminum Rear-front hinge pin holders. As for the rear shock tower,, I've never seen one of these break, I've raced mine for several seasons now w/o issue so I'd say the stock is just fine... but if you build your shocks wrong where they cannot compress fully or if you land upside down a lot or just right maybe? But under normal conditions the stock plastic works just fine.
TBH the only other part I have broke on my was the front C-hub, and you can now get aluminum versions of that part too.
8ight-e is offline
Old 10-05-2013, 07:31 AM
  #12498
EvanAZ's Avatar
Trader Rating: 99 (100%+)
If you put a 1mm shim between the rear shock tower and motor plate/tranny it won't break in that spot, or grind the motor plate just where it touches the tower.
Did this to mine after I broke one and could see where it touches when it landed upside down on the rear tower.
EvanAZ is offline
Old 10-05-2013, 09:15 AM
  #12499
RC10Nick's Avatar
really? My kit came with the crappy plastic steering rack. didn't know they changed that.
RC10Nick is offline
Old 10-05-2013, 09:26 AM
  #12500
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Me either, the kit I just opened had the plastic rack..Anyone looking for a +8 alumi chassis, I have one for sale..
flame56mx is offline
Old 10-05-2013, 09:55 AM
  #12501
Trader Rating: 30 (100%+)
My kit came with the plastic one too.
Otto.951 is offline
Old 10-05-2013, 10:03 AM
  #12502
I think only the DESC210 comes with Alum rack
cripplethreat is offline
Old 10-05-2013, 11:08 AM
  #12503
I ordered the kit yesterday and i dont have a clue what motor/esc i should go for. Im on a budget (student) so i was thinking of just getting a really cheap combo from hobbyking. just to get a start. What kind of specs should i look for?
Can i use this one? : (sorry i cant post links yet, but its on hobbyking and on the menu on the left -> electric motors -> motor/esc/prop combo)
Turnigy TrackStar Waterproof 1/10 Brushless Power System 4000KV/80A
ESC Specs:
Continuous Current: 80A
Burst Current: 95A
Resistance: 0.0009ohm
Battery: 2-3 cells Lipo (5-8 cells NI-xx)
BEC output: 6V/1A
Motor type: Sensorless brushless motors
Running mode: Forward only or forward with reverse (user programmable mode)
Dimension: 43 x 38 x 20mm
Weight: 88g
Motor Specs:
Model: 3650 Sensorless
Kv: 4000
No. of Poles: 2
Cont Current: 45A
Peak Current: 55A
Max Power (15sec): 370W
Winding: 16T
Resistance: 0.0125ohm
Weight: 180g
Diameter: 36mm
Length: 53mm
Shaft Diameter: 3.175mm
its 50 $... We are driving on carpet. Not very big track. If anyone have any other suggestions, please shout out
thanks!
these_savages is offline
Old 10-05-2013, 11:46 AM
  #12504
RC10Nick's Avatar
ESC Specs:
Burst Current: 95A
BEC output: 6V/1A
Weight: 88g
Motor Specs:
Kv: 4000
No. of Poles: 2
Cont Current: 45A
Peak Current: 55A
Winding: 16T
Weight: 180g
Diameter: 36mm
Length: 53mm
thanks!
I'd spend a couple more dollars and get a sensored setup.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
These two will run about $70. The combo you listed shows up as $60 on the US warehouse. If you're racing, especially on carpet, a smooth sensored setup will really make a difference.
RC10Nick is offline
Old 10-05-2013, 12:11 PM
  #12505
thanks man! looks good! Im not racing seriously (yet) just having fun at the track. btw. Ive been reading a lot on the 210 today, mostly in this thread, and i actually see some people say the would choose the RTR over the KIT? .. I guess the rtr really is a good deal now at 200 $.. What do you think?
I kinda promised myself after the last car i bought that the next car had to be a kit. i have a couple of rtrs already and really wanted a kit this time..
what really are the differences?
Old 10-05-2013, 12:16 PM
  #12506
Konich's Avatar
For the price I would buy the RTR kit and just upgrade it as you get more serious. The RTR kit is hard to beat for $180-$200 right now. You also get a decent brushless system that is sensored. The steering servo is the one upgrade you'll want to do out of the box.
Konich is offline
Old 10-05-2013, 12:31 PM
  #12507
Cream's Avatar
I got my Son the RTR which is great for the money.
Had a lot of upgrades since.
Speedo is good for 8.5 turn I believe.
The problem I had with changing the servo was the steering became to fast. With no way of slowing it down on the standard radio. So ended up buying him a new radio.
http://www.absima.com/en/products/co...tems/cr3p.html
Bargain for £55.00 Not sure if they are available over in the USA though?
Cream is offline
Old 10-05-2013, 04:25 PM
  #12508
tony montana's Avatar
Trader Rating: 76 (100%+)
Im sure this has been asked but is there any way to put 12mm hex on the rear of the car? I just have so many mounted tires on 12mm hex.
tony montana is offline
Old 10-05-2013, 04:34 PM
  #12509
just throw on a b4.2 12mm hex and pin and you will be fine.
glenng is offline
Old 10-05-2013, 04:53 PM
  #12510
thanks.
