Durango DEX210 Thread
I like that buggy class is growing and companies are really giving us a larger than ever choice of cars for this class. Downfall is at least when it was pretty much Associated and Losi for 90% of the cars we didn't have companies making cars every year or less. Not it is getting just like touring cars with a new car every 6 months to a year and raising the prices just like with touring cars. Its following the same cycle that killed touring car racing because of the car of the month club. Yes you don't have to buy but who wants the older stuff as it just gets hard to find parts unless you buy the latest and greatest.
I hope Durango follows a similar path where their redesigns are more evolutionary than say, Xray, like you mention whereby with each year you need the latest version.
How old are the 210 and 410v3? I'd have to guess about 2 years.
TD have released a Type B piston set #TD330590, comes with
2 x 1.6mm - 1 pair
2 x 1.7mm - 1 pair
3 x 1.6mm - 1 pair
3 x 1.7mm - 1 pair
blanks - 2 pairs
2 x 1.6mm - 1 pair
2 x 1.7mm - 1 pair
3 x 1.6mm - 1 pair
3 x 1.7mm - 1 pair
blanks - 2 pairs
Thank you Team Durango
Want the TLR 22 2.0 but when I can get the RTR for less than $200 out the door it's hard to resist. All I'd need would be tires since I have a Savox 1251MG and extra receiver laying around.
Tower has the dex210 for 135 and the rtr for 199 is durango getting ready to release a new car before worlds????
Guessing the new kit will cost $250-300. For $119, you may be able to upgrade for less than that.
On a couple pairs of out drives, it's really tight. I need to use a bit of force to get the thrust bearing in and I have a hard time getting the diff bearing out. Anyone else see this before? Bad batch maybe?
Tech Legend
Trader Rating: 51 (100%+)
The hard coating on the diff halves probably are just a little more than normal. Just use a fine piece of emory cloth and lightly saned it out just a little til it fits better for you. Sometimes when the hard coating/anodize is applied its just a tad more/less so it happens on occasion with all the companies soon or later.
yep, happen to me on a brand new set. I used a dremel and sanded it til they fit.
Just ordered a dex210. $124 from tower with cupon I could not stop myself. It will look good along side the dex410v3.
vr6cj,
What dremel tip do you use?
Whats the difference between 1.5° and 3°?
Whats the difference between 1.5° and 3° kick up?
