Durango DEX210 Thread
Good things come to good people. Tell the jackson crew i said whats up.
i got the rtr buggy it has two races on it and 4 sets of tires and a lipo looking to sell or trade for an 8th scale nitro or electric if anyones interested send me a pm.
Does anyone know off hand what parts are needed to convert to a mm? We run indoor med-high bite clay and was thinking of running mm. Any thoughts? You guys suggest mm. This will be my first buggy. I think as of now its in rm4. The motor goes in on the passenger side and spur and pinion are on drive side? And for mm part #'s. Thanks in advance.
PS. I'm running stock blinky. D3.5 17.5 stock ball diff. Any thoughts on gearing as well.
Appreciatie any info thank you.
#TD320126 wing mounts
#TD320121 rear bumper
#TD320127 chassis brace
Here's a link to the manual for the steps involved with changing to MM http://www.team-durango.com/pdf/manu...n%20Manual.pdf
For stock gearing 30-35T pinion and 69 or 75T spur is the general range, you will need to removed a bit of material from the gear cover so the pinion doesn't rub.
Team Spec 4mm Lowered Carbon Fiber Shock Towers
We have just released our Team Edition 4mm Lowered Rear Shock Towers, available for the DEX210 and the DESC210/DEST210. Please visit the website for more info -
http://www.diggitydesigns.com/index.html
Almost ready to ship. For Durango 210 series.
Triad slipper for Dex210. You can see the setup for other models on the Avid website.
Looks photoshopped to me. Think you better send me one to prove it Heard really good things. Can't wait!
Anyone run the tresery dex layshaft that let's you use the ae spurs and pads? Good/bad? Pros/coins? Thoughts?
DEX210 Triad Upgrade Pack
You can use the 1020-MOD or 1020-STK Triad Slipper Set with the DEX210 Upgrade Pack to outfit any Durango 2wd with the Avid Triad Slipper. The Triad Slipper Sets are $28 and then $15 for the Durango Upgrade Pack (topshaft, drive plate, gear cover). Lexan gear covers come pre-drilled, just trim the outside edges. Pic attached.
Or use the VTS slipper with a little mod and costs half that
