Durango DEX210 Thread
I found it can splatter on if the can isnt at room temperature, if its cold it hates it.
havent seen anything on here about fit or anything i just got my xtremerc rear camber mount, its 6061 aluminum so its a lighter color and lighter feeling than i expected, fits good with 2mm spacer under the camber link had to dremel off the gearbox tabs it has three holes the two inner are where the gear cases would be
Knowitall, I moved mine in 5mm and used about a 2mm drill bit. Works great.
Did the mod in about 5 minutes last night and it worked perfect. Looking forward to finishing the build and giving the 2 wheel drive buggy class a shot.
Anyone try removing 2mm from the gearbox to raise the roll center? I saw it on the AE thread, so I tried it. It really improves the rear rotation on high bite, clay surfaces.
Also saw that Jorn Neuman milled 2mm off the bottom of the rear pivot block. Wouldn't that just provide more kick up?
"On the rear of the car the lower rear wishbone mounts have been machined to be 2mm lower than the current lowest position which gives improve forward bite and better landing capabilities."
I can't for the life of me picture where this 2mm lowering is....?!?! Can anybody point this out? Are they talking about the RR hanger? The one in this picture... I assume.
R/C Tech Elite Member
From PetitRC (on Jorn's buggy)
Hey guys just getting back into 2wd. This is my second go round with the 210. I had the O.E. short aluminum chassis when it first came out, now I have the +8 plastic chassis. What is the norm for lipos? Long or short and where is everyone placing them. Front or back. If you could show me some pics of your setup it would be greatly appreciated. Also I am going to run a 10.5 in it. Stock spur and 25-26 pinion? Does that sound right? Thanks for any info....
Yeah, machining 2mm off the RR block, and then running an 0/3 Rf block would lower the arm pivots, and basically give you approx 2* of kick up. I have a piece with 1mm removed, and run the 1.5 block for 3* of kick, or 0* for 1.5*. I only removed 1mm as the arm/chassis clearance is minimal. Notice in the pic it looks like there is some chassis massaging..
Anybody running 6.5T motor? I'm looking for a ballpark FDR.
