Durango DEX210 Thread >
Like Tree80Likes
Old 10-16-2011, 12:02 PM
  #676
1armed1's Avatar
Trader Rating: 79 (100%+)
Pete,
Can you post a picture?
1armed1 is offline
Old 10-16-2011, 12:10 PM
  #677
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by FastPete
Im done only issue is the back is only a few mm off the ground. I could turn the spring collars up, but the issue is no droop? Its on the chassis droop screws all the way up. What did I do wrong?
Thanks Pete
pictures needed... multiple angles.
Cpt.America is offline
Old 10-16-2011, 12:13 PM
  #678
FastPete's Avatar
Trader Rating: 44 (100%+)
Not the best pics
Attached Thumbnails Durango DEX210 Thread-210.jpg   Durango DEX210 Thread-2101.jpg
FastPete is offline
Old 10-16-2011, 12:21 PM
  #679
FastPete's Avatar
More
Used the small droop screws with the small flat head on it right?
Attached Thumbnails Durango DEX210 Thread-2102.jpg   Durango DEX210 Thread-2103.jpg
FastPete is offline
Old 10-16-2011, 12:26 PM
  #680
ccarrtiger's Avatar
Default shocks
Did you by chance use short shafts on those rear shocks?
ccarrtiger is offline
Old 10-16-2011, 12:28 PM
  #681
FastPete's Avatar
No if you pull the shock off the bottom its plenty long. Its on the droop screws for some reason.
FastPete is offline
  #682
Have you fitted the correct shock shafts? Looks like you have the fronts in th rear.
Chris-s is offline
Old 10-16-2011, 12:31 PM
  #683
FastPete's Avatar
No The droop screws are sitting on the chassis. Thats why it wont come down. But why?
FastPete is offline
Old 10-16-2011, 12:35 PM
  #684
ccarrtiger's Avatar
Default droop
I pulled my droop screws out. I just prefer more travel. try pushing the wheel all the way up and take them out. See what happens then.
Old 10-16-2011, 12:36 PM
  #685
Matt Howard's Avatar
only a few people have them here in the states, I would take the rear suspension apart and put it back together again exactly by the manual, something isn't built right
Matt Howard is offline
Old 10-16-2011, 12:41 PM
  #686
FastPete's Avatar
Just screwed them up got a turn out of them a tiny bit better. Too bad the arm isnt countersunk so it would go all the way up like their not there.
What ride hight are u guys using? Or arms level?
FastPete is offline
Old 10-16-2011, 12:42 PM
  #687
FastPete's Avatar
I checked again appears to be right.I am using the 0 front block no anti squat
FastPete is offline
Old 10-16-2011, 12:50 PM
  #688
ccarrtiger's Avatar
Default DROOP
Although it comes with droop screws, the type of crew they selected used in the proper way gives you instant 1mm droop from the inside, try either pulling them out, turning the screws around or using a regular grub screw to allow full adjustement
Old 10-16-2011, 12:53 PM
  #689
FastPete's Avatar
That did the trick, will cut the head off and should be good.
Thanks to all.
FastPete is offline
Old 10-16-2011, 01:02 PM
  #690
wait, using the supplied screws automatically limits you to 1mm of droop? WTF?
