Durango DEX210 Thread >
Like Tree80Likes
Old 04-17-2012, 07:03 PM
  #5401
Trader Rating: 79 (99%+)
Originally Posted by DBL15
i noticed your now selling both durangoes mate what car you moving onto?
Really...
Raul Garcia is offline
Old 04-17-2012, 07:24 PM
  #5402
DBL15's Avatar
Originally Posted by Raul Garcia
Really...
yeh he put it in both threads the cars for sale and look like great buys as well
DBL15 is offline
  #5403
Autocratic's Avatar
Trader Rating: 26 (100%+)
Really...
I know, I know.
I'm just stuck right now.
The 210 is really frustrating me lately.
That car has everything it could possibly have to make it better, besides a carbon chassis, and this weekend I pushed that setup to the extreme and it was super fast, but still not fast enough to make the A Main in freaking 17.5 at my home track.
As far as the car is concerned, I think I hit a peak with it. I feel it's as good as it is going to get. Unfortunately I can't get the track time I would like with both cars right now, but I also spent two days of practice this weekend working on both trying to get them to work for me.
Autocratic is offline
Old 04-17-2012, 07:28 PM
  #5404
DBL15's Avatar
Originally Posted by Autocratic
I know, I know.
my guess is the weight in stock 17.5 racing , i know for a fact the guy the won the Australian title in stock was using a 210 but it had carbon chassis and carbon towers and a lot of other weight removed from it to be just legal weight
i admit they are not the lightest car out there thats for sure but a full weight version of the 210 won the mod class as well at the same event
DBL15 is offline
Old 04-17-2012, 07:31 PM
  #5405
Jmuck69's Avatar
Trader Rating: 14 (100%+)
If they come out with the composite one-piece chassis that should help and simplify the rear bracing.
Jmuck69 is offline
Old 04-17-2012, 07:34 PM
  #5406
Something makes me think we will see some new stuff soon from Tresrey, or TD.
Old 04-17-2012, 07:38 PM
  #5407
Jmuck69's Avatar
check out all of the new option parts they put on the website.
Jmuck69 is offline
Old 04-18-2012, 12:32 AM
  #5408
hacker's Avatar
Trader Rating: 141 (100%+)
I'm sure stock was not won by a durango 210
hacker is offline
Old 04-18-2012, 01:21 AM
  #5409
daverobbo5's Avatar
Trader Rating: 45 (100%+)
wasn't it Ash Anthony with an X6 based on the B4.
daverobbo5 is offline
Old 04-18-2012, 03:36 AM
  #5410
DBL15's Avatar
oh yeh i forgot i thought Scotty won it but your right that was the 4wd my bad
it was in the top 3 though
DBL15 is offline
Old 04-19-2012, 10:36 PM
  #5411
Trader Rating: 166 (100%+)
Just ordered this car and have questions about tools. What tool am I to use to install the circlip? Also the manual on-line mentions a .05 & 1.3mm Hex, I cannot seem to find those tool sizes anywhere, Is there a standard equivilent? Also the cross wrench I assume is the same as the one that comes in Kyosho and 22 kits, However I cannot find either of those tools. Any help in that direction would be greatly appreciated.
jpcopeland1 is offline
Old 04-19-2012, 10:51 PM
  #5412
Trader Rating: 19 (100%+)
The 1.3mm is the same as .050, a common size. Also need a 5mm nut driver and 7mm nut driver, and a 2mm hex driver. For the circlip you need a small set of circlip pliers- I got mine from Mac Tools and it was the smallest they had. I swapped a handful of button head screws for cap head, and those take a 2.5mm hex driver. The cross wrench isn't a must for building, but most any metric cross wrench will do as long as it has 5 and 7mm on it.
Jonny5 is offline
Old 04-19-2012, 10:54 PM
  #5413
Thanks Jonny5 I can get the circlip (snap ring pliers from Harbor Freight) I beleive. So the 1.5mm is the same as the .050, I assume the bleeder caps on the shicks are the same type screw that are on the AE Bleeder caps?
Old 04-19-2012, 10:58 PM
  #5414
Same style, longer screw though. Very nice, smooth shocks and easy to bleed.
Jonny5 is offline
Old 04-19-2012, 10:59 PM
  #5415
netmaster's Avatar
To install the circlip I used Craftsman snap-ring pliers. Worked great and not overly priced.
1.3mm and .05 inch are virtually the same size. If you have a set of standard hex wrenches, you probably already have the size you need. Here is just one you could get: ProTek R/C "TruTorque" Standard Hex Driver (.050")
No sure what you mean by cross wrench?
netmaster is offline
