Durango DEX210 Thread >
Like Tree80Likes
Old 08-20-2011, 09:40 AM
  #271
teeforb's Avatar
Trader Rating: 94 (100%+)
Also note, the 22T will have an option to use gear diff as well
teeforb is offline
Old 08-20-2011, 09:41 AM
  #272
Trader Rating: 21 (100%+)
Originally Posted by Rioga
Why you talk about OIL? In the gear diff of my b4 rtr i pur only black grease as manual says. Maybe you use OIL instead of black grease?
The Durango will be using a seals gear diff that you can toon the action with oil
O'donnell racer is offline
Old 08-20-2011, 01:20 PM
  #273
Hello guys , i write from italy and as many of you i'm waiting for the new durango.
I would like to understand why gear diff could be better than ball diff. Factory cars all come out with diff balls and i don't undestand why lots of you want to use gear diff.What Are the advantages?
Ps sorry for grammar errors!
For me it'll be intially about lower diff maintenance with racing one wet astroturf over the winter months. You can also tune the diff, but not sure how much benefit that'll be in the 2WD vs the DEX410
I'll still have ball diffs to look after from my TRF511 which won't be raced outdoors over winter.
mikeyscott is offline
Old 08-22-2011, 06:58 PM
  #274
Trader Rating: 54 (100%+)
everything on schedule release date? i hope so c'mon amain dont let me down
rkhess is offline
Old 08-25-2011, 12:37 PM
  #275
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Why are the TD titanium turnbuckles so f-in expensive? Lunsford needs to release some to fit.
Jmuck69 is offline
Old 08-25-2011, 01:09 PM
  #276
Trader Rating: 19 (100%+)
Unobtanium.....
Jonny5 is offline
Old 08-25-2011, 01:18 PM
  #277
Matt Howard's Avatar
Just find out what size you need and order the Lunsfords. I pieced together Ti turnbuckle kit for my DESC410R and it came out to around $30 if I remember right.
Matt Howard is offline
Old 08-27-2011, 08:03 AM
  #278
Trader Rating: 49 (100%+)
I just pre-ordered one, hope I don't regret it.
I'm hanging on to the b4 incase I go through the debacle I went through with the 410r.
If TD sucks with the support after this, I'm done with TD.
aradaiel is offline
Old 08-27-2011, 08:50 AM
  #279
Patience is necessary with a new platform, regardless of the manufacturer. My only concern is whether parts will ship at the same time as the kits- it would be no good to break an arm or hub and not have any spares. Short of that, I have no worries about the quality or fit and finish of the buggy- TD has won me over in that department.
Jonny5 is offline
Old 08-27-2011, 01:31 PM
  #280
Andy p's Avatar
Originally Posted by Jonny5
My only concern is whether parts will ship at the same time as the kits.
maybe not alot of use to you US lads but , the uk dealers are saying the parts are being shipped with the cars.
Andy p is offline
Old 08-27-2011, 02:32 PM
  #281
What was the issue with the 410R?
TD customer service when I had mine was spot on and very helpful team
Old 08-27-2011, 02:40 PM
  #282
Team Tekin
Randy_Pike's Avatar
Cars and parts are typically shipped together.
Randy_Pike is offline
Old 08-28-2011, 07:16 AM
  #283
This is a bit off-topic, but I was one of the ones to recieve the first kits. I got the first edition spur gears and destroyed 4 of them in 2 weeks. Durango told me I shimmed them wrong.
They also said I was a "bad driver" (they used other words, but same meaning) because I was breaking the front hingepin holders and popping off rod ends and they had no issues with them. Aluminum holders went on backorder for 2 months so my car sat on a shelf.
They sent me a PM once, offered to give me some stuff and I never heard from them again. I'm fully expecting to be on my own with this one, so I'm keeping my b4 just incase.
aradaiel is offline
Old 08-28-2011, 07:24 AM
  #284
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Really? Every time I emailed them with a problem or advice, they always responded. Not sure in your case but I have nothing but good things to say on my end..........sorry for your inconvience.
Bman's 3XNT is offline
Old 08-28-2011, 10:45 PM
  #285
FACTORYBUTNOT's Avatar
Maybe you are a bad driver! Jk...
One of my local shops stocks TD now...few of the local guys are liking the sc truck...
Another option fo sho
FACTORYBUTNOT is offline
