Durango DEX210 Thread >
Like Tree80Likes
Old 03-02-2016, 07:24 AM
  #17461
High grip clay where slicks are run, 4K with 4 planetary gears seems to work well.
fredswain is offline
Old 03-02-2016, 10:01 AM
  #17462
Thanks Fred. If watering level is good some guys run slicks or very worn tires with sauce. Mostly tires are like electrons/ chainlinks. Do you think I should try 4000 with that situation or go up or down in viscosity?
I'm running 7000 now with 4 plastic planetary gears in my DEST. Little loose if I get in it too hard. Was going to try 5000?
Thanks!!
WallyRC is offline
Old 03-02-2016, 10:49 AM
  #17463
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
sounds like a good starting point to me. The carpet where I go is cold as its in a basement and since I run slicks I would say is probably medium traction starting out. I am liking 5K right now for the dex210 plan B I have if I recall correctly. So 4K could be nice.
With the dex20F being so quick to get to the diff, I'll probably experiment more, though the outof the box setup is really nice.
Cain is offline
Old 03-04-2016, 11:44 AM
  #17464
Default DEX 210 V2
I think I just bought the last V2 from tower for 149.00
sgtlt is offline
Old 03-04-2016, 11:56 AM
  #17465
Tech Legend
Cain's Avatar
i Remember then being $160, dropped again huh?
Cain is offline
Old 03-04-2016, 12:19 PM
  #17466
Damn. I just bought a used V1 roller back in January for $100. Although mine also came with a custom graphite chassis.
emerilnut is offline
Old 03-04-2016, 12:21 PM
  #17467
discount cupon for 20 doll
sgtlt is offline
Old 03-04-2016, 12:28 PM
  #17468
Kremzeek's Avatar
Damn, I looked a week or two ago and they were all sold out. I was going to buy a second one for parts.
Kremzeek is offline
Old 03-04-2016, 12:53 PM
  #17469
call them, it said sold out today also so I called and the nice lady said they had one.
sgtlt is offline
Old 03-04-2016, 04:19 PM
  #17470
JRSlash's Avatar
Anybody has issues with front a arms. I didn't really have any serious crash last race and after inspection i found this.
JRSlash is offline
Old 03-04-2016, 04:22 PM
  #17471
JRSlash's Avatar
Arm is not even scuffed, only two races on it.... is this gonna be an ongoing issue?
JRSlash is offline
Old 03-04-2016, 04:58 PM
  #17472
Tech Legend
Cain's Avatar
Seen another post about this, I would contact hobbico about it.
One thing mentioned is to boil the a-arms.
Cain is offline
Old 03-04-2016, 05:50 PM
  #17473
Trader Rating: 270 (100%+)
I know I seen it some where what is the differance in the V2. VS V3. 210
Er8sr is offline
Old 03-04-2016, 06:48 PM
  #17474
Laker67's Avatar
Trader Rating: 69 (100%+)
I dont ever put in the droop screws in the front or rear arms. I have had a front arm crack trying to put in the droop screw in before. If your gonna limit down travel we should be doing it in the shocks. It's more consistent and less damaging in my opinion.
As for the crack on the back side of the arm. It may have been a freak occurrence.
Laker67 is offline
Old 03-04-2016, 07:04 PM
  #17475
Kremzeek's Avatar
Yeah, I just cracked a couple of front arms right by the droop screw. It wasn't from racing though. They cracked when trying to put the droop screw in.
In case anyone is wondering, I worked with Durango to figure out what the problem was. The droop screw I was using was about 4/100 of a mm larger than it should have been and that was making it crack. Yeah, talk about tight tolerances.
Kremzeek is offline
