Durango DEX210 Thread
There's nothing wrong with rear motor!
It has been a long time coming but I now have carbon fiber chassis blanks with a nose kick. That means that hopefully I'll finally get on with a new 210 chassis design. It just takes time which is something I don't have much of. I now have 20°, 25°, and 30° kick options. Getting warmer!
Do you know what offset the standard ones are? You only get two -2 per pack of four as it also comes with zero offset.
Thanks for that setup Pittster, but just maxing the collars still leaves with with 30 mm front and 25 rear.
I could lower it via droop screws as well. I don't need more steering, traction roll is my main nemesis right now but I do need to get it down lower.
What springs do you have installed ?
What springs are on your buggy? 30/25mm is pretty high for the collars wound up fully.
I run outdoor clay and I prefer the mm4
Sounds good!
Looking forward to see the final product...
Chucked some dark blue springs on mine and it was sitting at 26mm with 3mm preload, no battery installed and the knuckle spaced up 2mm.
Does anyone know where to get the sidepod aluminum spacers that extend the v1 sidepods with the front chassis brace when using a +8mm chassis? I was wanting to use my Jconcepts body and with the v2 sidepods i cant.
It is a V1, and I was recently convinced to run the V2 arms. Is there a step in installing the V2 armsI am missing that is causing the ride height issues? I also have V2 towers.
Which spacers are the steering knuckle spacers? I am not sure what part you are referring to. Are these the ones behind and infront of the caster insert?
Rebar tires on standard looking rims.
I can't think of anything that would case the difference in ride height by swapping arms. Could you take a picture so we can see if there is anything wrong?
I was refering to the spacers above/below the knuckle.
