which 10th scale brushless package would i get?
#16
ezrun - no
#18
lrp 6.5 w/sxx tc spec
#19
I would start with the 15T, and check your temperature after a few minutes. I am pretty sure you can run alot higher without overheating if you can use the speed. If it works out fine with the 15T, I would pick up more pinions of larger sizes and go up until you get all the speed you need while checking temp often. Dont let it run over 180F and you can gear however you like.
#21
I would not try it, but it would prob be ok. Definitely not going to be covered under warranty.
#24
are you talking about a 1/8th scale truggy? People used MM and pushed it to its limit before the MMM came out for 1/8th scales.
One of the big difference between the Sidewinder and the MM is the maximum current rating... Sidewinders are a "light" version of the MM. MM is like a light version of the MMM...
If you're doing 1/8th scale, just get a proper 1/8th scale ESC... I wouldn't risking a nice Sidewinder for it...
