Kyosho MP9E Thread
#3016
this will depend on how much you crash
i have never broke a tki4 arm, the only part that i replace regularly is rear brace, if the brace is compromised in any way it needs to be replaced, if you run with a bent brace you can easily bend the chassis especially on the heavier mp9e..
Point taken mate...Cheers.
#3017
What body does everyone prefer to run.
#3019
#3023
Think Reedy's are the same size.
#3024
Been running these https://www.amainhobbies.com/team-or...i14084/p485234
#3025
Weight doesn't win or loose races in 1/8. This isn't 17.5 blinky.
#3026
the placement of our added weights does though
Before switching from Kyosho, I had raced the MP9e in every iteration and was never at a disadvantage, weight / performance, or any other way. It is a safe buggy to run, very planted and forgiving of driver errors.
Can't go wrong with the MP9e!
#3027
Hi, I have done a electric conversion (TKI4), but the center diff posts don't align. In the conversion manual, it says use the standard front upright??? Any suggestions???
#3028
Use the other upright.
#3029
#3030
Yeah, like others have stated that's the rear upright. The first picture has the truggy top plate as well. Its a little to long.
