Kyosho MP9E Thread >
Kyosho MP9E Thread
Like Tree121Likes
Kyosho MP9E Thread
    Hide Wikipost
Old 11-25-2016, 05:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho MP9E Thread
Last edit by: tobamiester
Kyosho MP9e Wiki.
Mp9e TKI4 Manual
Print Wikipost
Old 10-28-2013, 04:09 PM
  #1726
Originally Posted by Jpm1
Mine did come with white extra pistons but they were 1.2 x 8.
My new Mp9e TKI came with white 8 x 1.3's I'm pretty sure..
Man I raced the DUEL this weekend.....Proline Test Track on saturday and Thunder alley on Sunday....
This car is really good.....I had a blast.
Oh and by the Way..Drew Moller won the event with his Mp9 Tki3
Jason Snyder is offline
Old 10-28-2013, 04:15 PM
  #1727
Jpm1's Avatar
Originally Posted by MySlowZ
Decided to go with mp9e tki over the mugen Eco m spec. Simply because I wanted it in kit form. This will be my first 1/8 ebuggy. Now that I've decided on wich buggy, I need help with deciding on what electronics I should put in.
So far I think I'll be going with the tekin rx8 gen2 and T8 motor combo (any other suggestion are welcome). What motor KV are most running ( 50/50 bashing and racing). Haven't ran @ this track before but its a medium size medium bite track.
As for servo & battery not sure yet.., need suggestions. My budget is $100 for servo and maybe $140 for a 4s. Also does the mp9e tki accept side by side (like 2s+2s) If so, what do most prefer, single 4s or 2 2s?
I think that's about it for questions. Thanks for any help.
I'd go a gen2 1900t8 combo.
I'd try and get a high voltage servo as the gen2 rx8 can run 7.4volt output.
Batteries I'd go with smc 4s packs and will almost get 2 for $140 or if you have cars that run 2s packs you can run those side by side.
Jpm1 is offline
Old 10-29-2013, 02:21 PM
  #1728
carpet Carlos's Avatar
What other body fits this car i do not like that stock k body ae bodys ?
carpet Carlos is offline
Old 10-29-2013, 02:28 PM
  #1729
Jpm1's Avatar
I'm using the ftw night fox body for the tki3 nitro, it just touches the battery but not enough to worry, looks awesome.
Cheers justin
Jpm1 is offline
Old 10-29-2013, 02:35 PM
  #1730
Cheers justin
I will for sure run that on the nitro
Old 10-30-2013, 09:49 AM
  #1731
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Cheers justin
I like that. My favorite is the MP9 nitro JC Finnisher body.
Posvar is offline
Old 10-30-2013, 10:41 AM
  #1732
Wow I can't get over how tight everything fits. There is no play anywhere on this thing. And the drive train....don't get me started. it's so smooth and free
turtletrax is offline
Old 10-31-2013, 05:08 AM
  #1733
Guys try ing to stock up on back up parts what do i need other than front upper and lower a arms. Also are there many differences than the tki3 because I'm ordering that also thanks
Old 10-31-2013, 06:35 AM
  #1734
Carlos
When I had my Mp9e my parts box had gearboxes, arms, pair of c-hubs, pinion gear for the gearboxes, all the plastic parts that going on the shocks, wing stay mount, chassis braces. Basically I had just about all the plastic parts for the car. This car is pretty durable. It will take a beating. Gear wise just make sure everything is shimmed properly. This car will last a long time when taken care of.
Have fun
Mark
donthatethegame is offline
Old 10-31-2013, 06:37 AM
  #1735
Also tki3 parts are the same as mp9e. You can keep one parts box for both.
Old 10-31-2013, 08:20 AM
  #1736
Does anyone know the length in mm of the center drive shafts on these cars?
homershoots is offline
Old 10-31-2013, 09:09 AM
  #1737
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
84mm front
110mm rear
Stocks are universal joints, but they also make CVDs.
SEF is offline
Old 10-31-2013, 09:32 AM
  #1738
Originally Posted by SEF
84mm front
110mm rear
Sweet! The truggy rear is 113 mm and the buggy rear is 110! That's great they will fit perfectly in my associated which has 110 front and 113 rear. The pinions have the same bearing size so these should work no problem. Sooooo tired of the captured pin cvds on this thing.
Old 10-31-2013, 09:49 AM
  #1739
Can you finangle the diff out with just the front split mount(i assume they dont make one for motor side) Thats my only complaint is diffs are a pita
Old 10-31-2013, 10:52 AM
  #1740
Diffs are a pain in every car except the Durango LOL, on the ae car with ft motor mount the center is pretty easy, my buds Kyosho not so much. I love the Kyosho just not the price but you defo get what you pay for. What an awesome car!
