1/8th buggy ep conversion HELP !!! >
Old 09-24-2009 | 03:41 AM
Questions?? 1/8th buggy ep conversion HELP !!!
Hi , im in need of sum advise .......
Iv jst built a 1/8th brushless buggy , im using a 1/8th losi excelorin esc and a feigao 6xl motor
Wat would be the best battery to use ?? the esc has a 5s limit and the motor draws 110amps ....
I was thinkn i might run two 2s lipos 5000mAh 30c much cheaper than 1 4s of equal specs ect . I just dnt know if i can do this or not ???? How would i connect them up ??
Here sum pics of my set up
Attached Thumbnails 1/8th buggy ep conversion HELP !!!-dscf0214.jpg   1/8th buggy ep conversion HELP !!!-dscf0213.jpg
robrc12 is offline
Old 09-24-2009 | 04:02 AM
lowcel's Avatar
Here is the battery that I am using. Pretty hard to beat for the price.
http://hobbycity.com/hobbycity/store...00mAh_4S1P_25C
lowcel is offline
Old 09-24-2009 | 04:16 AM
SWeet looks like a mean deal .... im frm new zealand so il have to check out the postage cost 1st
Thanks mate
robrc12 is offline
Old 09-24-2009 | 04:26 AM
jmcvicker's Avatar
The 6XL motor is higher KV. Appears to be a 2779KV. I run a Castle 2650KV motor and it is fast and raceable with a 3S1P battery. I use the Zippy Flightmax 5000mAh 30C battery (from Hobby City) and it runs a 10-minute race fine. Borrow someone's battery first to test out your setup - don't blindly buy stuff without at least trying various options.
If you run a 4S1P battery, gear it down low (10 or 11T pinion to start) and monitor heat closely in the ESC.
My son runs a Fiego 10XL in his buggy with 4S and it's a little slow compared to competition, a 9XL would be perfect at 1900KV.
jmcvicker is offline
Old 09-24-2009 | 05:38 AM
kufman's Avatar
What is the ratio of your additional gearing that is attached to the motor?
kufman is offline
Old 09-24-2009 | 09:36 PM
Hey , its setup 1:1
The pinion gear im waiting 4 is a 15t , im thinking that a 10t will be better tho . il see how it goes and then decide wat to do / ask 4 more advise haha
robrc12 is offline
Old 09-24-2009 | 09:43 PM
TomTomTuning's Avatar
Alot of people have used the zippy's with good success.
I personally run Epic IP5000mah 40C 4s2p, but these are like 130.00 each.
If jmcvicker is correct about the motor being a 2779KV motor, then 4s might be a bit much... You will definitely need to watch heat and gear it down.
3s would be perfect.
TomTomTuning is offline
Old 09-25-2009 | 06:12 AM
If you race, with a 4S lipo on that high of a KV motor it will be too much. I don't think you can gear down low enough to make a difference. 3S will get you were you want to be.
The zippy packs are great but make sure you velcro it to the bottom of the chassis as well as using your straps because they tend to crush easy. You do not want it to move in the tray at all.
JoeC is offline
Old 09-25-2009 | 06:39 AM
glassdoctor's Avatar
Your esc will not like the 6XL... it's a speedo heater
glassdoctor is offline
Old 10-01-2009 | 07:44 PM
Yea so iv been told
im goin to get a mmm instead shuld go alot better too
robrc12 is offline
Old 10-01-2009 | 07:49 PM
thecman26's Avatar
R/C Tech Elite Member
Originally Posted by robrc12
Yea so iv been told
I just got 2 of these!
http://www.hobbycity.com/hobbycity/s...0mAh_4S1P_30C_
Work fantastic!
thecman26 is offline
