Timing Adjustment, What's it do? >
Old 10-12-2003, 09:37 PM
LosiFromHell986's Avatar
Default Timing Adjustment, What's it do?
Hey I just bought an motor with Adjustable Timing, and I was just wondering, What's it do to Adjust it? Please Explain as well as you can, for I have NO clue....
Jeff
LosiFromHell986 is offline
Old 10-13-2003, 03:53 AM
sosidge's Avatar
Increased timing will increase power, but decrease efficiency. Don't go beyond 24 degrees.
A safe setting for most motors is around 12 degrees advance.
Retarded timing should never be used.
sosidge is offline
Old 02-07-2004, 12:38 PM
Suspended
Cool Motor Timing
Never decrease timing. Increasing it will definitely give you more power and RPM. I personally use 5-10 degrees to give me a little more scoot without too much wear on the motor. If you go too high you will get more no-load RPM, but all that does is waste power.
tmeeks is offline
Old 02-08-2004, 01:48 AM
dragster's Avatar
Default Mod Motor Timing
Hi ,
There's a Great Feature on Motor Timing in latest Radio Control Car Action, Jan 2004, great reading if your been racing Stock... Hope that helps, Luke.
dragster is offline
Old 02-08-2004, 03:46 PM
Scrubb's Avatar
Increasing timing increases the RPM of a motor and reduces Torque. The motor will still make the same total horsepower, but its powerband will be different. Its a trade off.
Use more timing on tracks with lots of turns, jumps and short straights with a smaller pinion gear. Higher timing also drains the batteries faster, and causes more arcing in the motor so use a slightly stiffer brush spring.
Use less timing on larger, tracks with more straights with larger pinion gears.
Scrubb is offline
