HPI Vorza Flux 1/8 E-Buggy Thread
#496
Instead of buying that "y" Type connector it is easier and cheaper to just take a dean connector and solder a bridge across its terminals shrink wrap it and simply plug it into the unused esc dean.You can tie wrap the lead out of the way cleanly making it look alot better and managable plus if you ever need the other lead just unplug your little dean plug you made and your set.I did this with a novak on my TXT and it works fine.
Also the pull apart guys are on ebay for the Vorza.I just won 4 out of stock anywhere else items however some guy paid 48 dollars for whhel nuts and the adapters they screw on.A little high I think.
#497
Paulie, thanks for the review. I am setting up a vorza for racing and have the same setup. I am eagerly waiting on your report of the longer rear shocks as I am tyring to decide if they will be a waste of my money or not. I hear the stock ones are pretty good.
2 questions:
1-I have unthreaded the rear shock ends so about 3 threads are showing which makes the hole to hole distance 100mm. Is this the correct way to measure the droop?
2-what hole are you running the rear hub in where the outer hingepin goes through? There are 2 holes stacked on top of each other. My Vorza came in the upper hole but the D8 comes in the lower hole. I put mine in the lower hole thinking this will give me more ground clearence and suspension travel. What is the effect of making this change going to be on the track?
Dan
2 questions:
Dan
Mine are both in the upper hole. Keep in mind that the Vorza came with the rear hub in the rear position. I wanted a shorter wheelbase like my D8 so I moved the spacer to the rear.
Hope that helped some.
- Paulie
#499
I will reply back with a comprehensive guide that will answer all your questions.
- Paulie
#500
Personally I prefer a single connector off the esc, so I cut of the oem deans and went with trx. Then I bought a Y cable incase I want to run 2 packs, which will be handy as I just ordered two 2s 5200mah turnigy hardcases. Otherwise I have a single trx coming of my 6s pack to use with the esc.
#501
Apparently they have 8 guage wire on the batts, are the traxxas connectors easy to solder?
#502
#503
My VORZA
Got my new VORZA in the mail last week (unfortunately cannot post pics easily due to r/c tech newbie status) however it's still stock so it's been shown before many times. (Although I did remove 99% of the stickers to give it a cleaner look).
So far very happy with it. I've had nitro cars/trucks in the past but this is a whole different kettle of fish. Heavier than I was expecting however when I go from NiMh to LiPo soon that should be helped. Acceleration out of the hole is very impressive. My modded traxxas slash needs a 20 foot run-up to jumps that the Vorza needs 3 foot run-up to clear. Though like some I've experienced the juttering under full amp load. Can't say I've tried 25c+ LiPo yet so probably can't comment just yet. I do operate it under powerlines so that could be the issue.
Anyway it's good to be back in this hobby, I look forward to racing the Vorza and learning more from the folks in this forum.
As mentioned, can't post pic links, so delete the space between the "ht" and the "tp"... cheers,
ht tp://photos-f.ak.fbcdn.net/hphotos-ak-snc3/hs158.snc3/18538_311214013407_522208407_4803068_5512251_n.jpg
ht tp://photos-d.ak.fbcdn.net/hphotos-ak-snc3/hs158.snc3/18538_311214018407_522208407_4803069_8142054_n.jpg
ht tp://photos-h.ak.fbcdn.net/hphotos-ak-snc3/hs158.snc3/18538_311211808407_522208407_4803060_6929158_n.jpg
ht tp://photos-b.ak.fbcdn.net/hphotos-ak-snc3/hs158.snc3/18538_311211813407_522208407_4803061_33614_n.jpg
ht tp://photos-d.ak.fbcdn.net/hphotos-ak-snc3/hs158.snc3/18538_311211818407_522208407_4803062_5378598_n.jpg
ht tp://photos-f.ak.fbcdn.net/hphotos-ak-snc3/hs158.snc3/18538_311211823407_522208407_4803063_7356237_n.jpg
ht tp://photos-g.ak.fbcdn.net/hphotos-ak-snc3/hs138.snc3/18538_311211843407_522208407_4803064_7048330_n.jpg
ht tp://photos-c.ak.fbcdn.net/hphotos-ak-snc3/hs138.snc3/18538_311214003407_522208407_4803066_7569559_n.jpg
ht tp://photos-e.ak.fbcdn.net/hphotos-ak-snc3/hs138.snc3/18538_311214008407_522208407_4803067_1893548_n.jpg
#504
Hobby king lists these batts as 26 mm, and some one posted up the vorza battery width as 51, so running two of these could be a tight fit? I'm about to order some of these batts too, very cheap!
#505
wrexxy, nice pics. I always wondered what it would look like minus the decals. Yeah the Vorza is a beast vs a slash. Once you go lipo it will be so much better.
#506
So i went to the track this weekend and Ebuggy is still pretty new in my area only about 5-6 of us total at the moment.
Anyways my Ve8 was sidelined with electronics issues from last week and the owner asked me to drive and make some changes to his buggy.
It was an RTR untouched vorza. I put white front, yellow rears, 27mm front ride height 28mm rear, full droop in the rear, minus 2mm in the front (i had no tools to measure this was a quick hack job setup) A set of medium city blocks and BAM.. was able to win the Amain at my small club race.
With a little more time i think i could have had it as fast and smooth as my Ve8 bit i was fairly impressed with it for stock electronics and things.
if someone was set on a RTR brushless buggy THIS WOULD be on the top of the list for SURE.
#507
OWTKAST - I would change the center diff oil too. It's really heavy, like 100,000 wt. for bashing and not racing.
I've got 5k front, 5k, center and 2-5k in rear.
#508
5k front, 5k center and 5k rear is my favorite so far. I've seen lots of d8 setups using 2k in the rear. It seems to be too loose for me on the Vorza
#509
I will never drive the car again just kind of got thrown into the deal with what i had. He emailed me today and was AMAZED.. cause it was AWFUL my first qualifier.
I will pass the knowledge on to him for sure though.
#510
1. The rear body mount snapped off. Having a closer look at the design of it, I'm not surprised. By the way getting the body on and off this thing is a pain in the proverbial. I think I'll have to trim it a bit and use some velcro on the tray instead. The clips are also a bit of a pain to get off unless you have smaller than average hands.
2. As mentioned previously, I'm relegated to my nimh packs until the next paycheck. Nose dived on a landing and the weight from 14cell worth of heavy battery decided to crack the front of the battery holder. Can't get those lighter/faster LiPo's soon enough!
Also I really need to figure out what setup to use to have less bottom-out on landings. Would a much thicker shock oil help? I don't want the rebound rate to be overly slow. I don't think I'll be doing much bashing with this thing. Mainly track and road.
