Jammin SCRT10 Thread
#9331
hey guys i have a first gen jammin that i am selling for $200. comes with losi eight scale shocks and a bunch of parts like the losi shock tuning kit.
http://www.rctech.net/forum/r-c-item...shock-mod.html
Last edited by Pimpin; 07-24-2011 at 07:38 PM. Reason: oops price was without the losi shocks. lol
#9333
Get away from the novak, I had them go up in smoke to.... and the tekin rs pro will not work with out some mod's, but was not that reliable because of SCRT-10 weight.... I when to a castle MMP and a 1410 3800kv 4 pole motor setup and love it...It is so fast and smooth..... The RX8 is good to but for the money MMP is the way to go...
#9334
I was thinking of doing the same but with a O.S. .18 TZ. LMK how it turns out for you and I may still do mines and get a Losi ten SCTE instead for electric. It would make more sense to me as I have both nitro and electric 810 buggies so parts would all be interchangeable.
#9336
im having problems with my mmp. I just got it today and soldered it to my battery connectors and to my motor and went outside to run it. I am very pleased with the peformance but it often will glitch. almost like super cogging my motor is sensored and sensor wire is plugged in but it will just loose all control and start to slow down then it will come back speeding ahead for about 3ft then have no power then go again. (full power-no power-full power-no power then works fine) all this happens in about 1-2 seconds. it is very frustrating and IDK what to try to do.
#9337
Cheers Mario
#9338
Running 2s lipo. Low voltage is at 6.2v batteries are fully charged and top of the line.
#9340
Proteck 5000ah 35c and hs-5645mg
#9341
The MMP has a weak internal BEC and when used with good servos youl get glitching problems hey...
#9342
Start power on low and make sure your steering endpoints are set proper. Mine were to close to lock and it would cause voltage drops . Might double check solder joints too.
#9344
The mmp BEC is changeable with castlelink default is 5.5v you need to up it to 6.0v or 6.5v is with I run with good servos and no problems. Or add a power cap or external BEC... I have 35c and 40c lipo with no problems but make sure your connectors are high amp and fit nice and tight with good solder jobs...
#9345
Resoldered reciver antenna fixed it. Thanks for the help.
