Help for Lipo Recommendations
I need recommendations for Lipo Packs.
To fit on 1/8 truggy on 2050kv motor. I suppose 8000mAh packs will be able to last 20min at least. I know Maxamps have them but what other brands can be considered?
My battery tray can accomodate length - 140mm, Width - 47mm, Height - 31mm or if need be, batts will additional height will be secured with Velcro straps.
Maxamps is just so expensive... $200+ for a battery?
My apologies. I did not mention that I run my Battery setup in Series. That's why I listed my preferred options of 7.4v, 2s. I'm currently running on 2 x 2s 5000mAh lipos in series which can give me abt 15min of runtime. Tht's why I need something that's higher than 5000mAh but still 2s.
My set-up: 2 x 2s 5000mAh in series, 2050kv motor, 43/10 front/rear gear ratio, 62t Spur, 16T pinion.
So, based on the expended mAh, I should need at least 6500mAh packs to last 20mins.
Glassdoctor:
Wht setup do u have on yrs?
I saw those too but am not sure if 6000mAh will last 20mins. I consumed abt 2300mAh in the 7min Heats during the last race.
Glassdoctor:
Glassdoctor:
I know you're only trying to change one parameter - battery capacity. Is that strictly all you can change?
Once you get past 15-minutes, you have to really look to lower the KV in the motor and go with more cells. 5S1P in a 1600KV motor will give you 20+ minutes. Heck - use 3 x 2S1P packs wrapped up into a series 6S1P and use a 1200-1300KV motor, perhaps. That's what some guys are doing for longer Truggy races. They seem to do this after first going for higher KV motors.
