*****YOKOMO BMAX 4***** >
Like Tree5Likes
Old 05-23-2015, 09:33 PM
  #2416
Khador12's Avatar
The hexes on the front AKA wheels fit snuggly and I am using Avid serrated wheel nuts(they have aggressive serrations). The only way I can them falling off is if the hex spins in the wheel and twists the wheel nut off.
Wildcat these are the front wheels.
http://www.raceaka.com/110-HEXLITE-4...SHO_p_594.html
Khador12 is offline
Old 05-24-2015, 07:07 PM
  #2417
=FLIP='s Avatar
Trader Rating: 24 (100%+)
New bmax 4 iii finally finished
=FLIP= is offline
Old 05-24-2015, 07:34 PM
  #2418
duckman996's Avatar
Trader Rating: 14 (100%+)
How'd you mount the wing? Did you cut off the nubs and drill holes for the 2mm screw?
duckman996 is offline
Old 05-24-2015, 08:15 PM
  #2419
FLHX1550's Avatar
Just use the wing mounts for the YZ-2, they bolt right on
FLHX1550 is offline
Old 05-24-2015, 10:22 PM
  #2420
symmetricon's Avatar
Trader Rating: 27 (100%+)
aluminum center driveshafts?
symmetricon is offline
Old 05-24-2015, 10:29 PM
  #2421
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
yeah Lee martin uses them. you have to order from europe
Wildcat1971 is offline
Old 05-25-2015, 12:11 AM
  #2422
C/F chassis huh? Looks good.
Piles is offline
Old 05-25-2015, 05:04 AM
  #2423
Very nice bmax4 3...
Aussie RC is offline
Old 05-25-2015, 06:11 AM
  #2424
hollywood3705's Avatar
Yokomo europe has lightweight center shafts, input shafts, and lightweight diff gears. It seems we are about 2 to 3 months behind in the us. Amain should carry those items bit obviously Europe is first. The cars are very popular there and the lightweight parts and hopups are grabbed up quick
hollywood3705 is offline
Old 05-25-2015, 06:54 AM
  #2425
FLHX1550's Avatar
AMain was an improvement for importation for Yokomo in the U.S., but you can tell there is no one that is focused on the product as their is no emphasis to carry the hop ups and maintain inventory.
FLHX1550 is offline
Old 05-25-2015, 09:10 AM
  #2426
I don't think that's the problem. Supply and demand and production runs are the main reason. Yokomo just doesn't sell offroad stuff. Drift is huge in japan. That makes offroad parts run less. Not amain fault it's just global supply and demand
Old 05-25-2015, 09:31 AM
  #2427
how does that battery mount system work?
Old 05-25-2015, 09:51 AM
  #2428
what is the best way to eliminate some of the bump steer on this car?
Old 05-25-2015, 01:19 PM
  #2429
It comes with the psm carbon chassis. It's made as a conversion. I may be wrong but I don't think it works on the stock chassis
Old 05-25-2015, 01:47 PM
  #2430
yeah, I am just trying to understand how it works. I saw some picks and guess I see. looks complicated
