Any TIPS on soldering up a TEKIN RS Pro??
#17
#19
The best way for a good, clean, wiring job is to plan it out not just wing it.
Checkout the show your wiring threads in both offroad and onroad electric for some good ideas.
http://www.rctech.net/forum/electric...-thread-7.html
http://www.rctech.net/forum/electric...tion-pics.html
#21
Not sure if this link will work but it is a good how to video from team tekin.
http://www.youtube.com/watch?v=5QktbPHdvQA
#22
IT's not as important to get the wires in the grooves of the Rs line as it is in the Rx8.
The best thing is making sure your joint is solid,secure, and CLEAN!
The biggest thing we see is either TOO much solder, or NOT enough solder.
The best way to learn soldering is by watching someone that knows how.
#24
+ YouTube Video | |
#25
R/C Tech Elite Member
Nice Vid!
I'd suggest one thing though...
After you clean the tip of the iron, and before you go on to the next wire or joint, tin the tip of your iron as well.
Helps transfer heat faster, and as such helps the solder flow better.
Flux obviously helps, but the best way I've found is to tin the iron just a bit before starting a joint.
#26
I found soldering the wires to the RS Pro was much easier than most ESC's. I used a 60w iron and (very sparingly) liquid flux. In 4WD offroad buggy ran the wires straight up off the esc posts to go over the upper deck. Prepped (filled) the esc post slots with solder, pre-soldered wire ends, tin the iron tip and soldered end of wire to end of post simultaneously. I definitely needed a hot iron to quickly melt both wire and post soldered ends together without overheating ESC post.
#27
This is how I soldered the wires on my Tekin RS:
This is 14Ga wire. First I whipped the ends (with 26Ga bare wire). If you don't know what "whipping" is look here: http://en.wikipedia.org/wiki/Whipping_knot
After whipping (but before tinning the wires) I flattened them in the jaws of a pair of pliers to the point where they would fit in the solder post slots, then tinned the wire ends. Put some flux in the slot, put the wire in, then hit it with the iron, and you see what I got. I use a weller 4033S chisel tip iron. It is only 45 watts but has an 1100F tip temperature and will solder most anything RC related very quickly.
For the person that already had solder on the RS posts, put flux on them, hold the ESC upside down, and touch the posts with an iron. The solder will melt off and flow onto the iron where it can easily be wiped off. The whipped, tinned ends of the wire are relatively stiff so they would be able to fit in the slots as the solder melts without needing to remove the solder that was there.
Flux is very important to get joints like you see above. I use paste flux every time I touch an iron to a joint.
