LiPO Saddle Pack Dimensions
I was investigating LiPOs that might fit my new D4, and I figured I'd share the info I found.
Manufacturers, if you have a hard pack you'd like to add to my list, please reply with the information in the same format that I have listed here.
NOTE: dimensions and weight are taken directly from manufacturer where possible.
ROAR Approved LiPo
EFRA Approved LiPo
HARD-CASE
SOFT-CASE
(1) - Trakpower lists weight per half of the saddle pack, so the weight probably doesn't include wiring either.
(2) - v2 SMC specs come direct from Danny at SMC.
(3) - no weight on official page at AMainHobbies.
(4) - via tower hobbies, no official data available)
(5) - info direct from ThunderPower RC. I called them myself.
(6) - direct from SMC on RC/Tech.
(7) - user submitted
ROAR Approved LiPo
EFRA Approved LiPo
HARD-CASE
- CORALLY 4200 LiPo - Saddle Pack - Hard Case (7,4 Volt / 35C) #48243 EFRA
- Fantom Pro Racing Series 5400 mAh 40C 69mm x 46.6mm x 28.5mm 325g ROAR
- Intellect IP 4200mAh 30C 69mm x 46mm x 23mm (7) ROAR EFRA
- Intellect IP 6000mAh 30C 69mm x 46mm x 31mm (7) ROAR
- Losi 4800mAh 2S2P LiPo 20C Saddle Pack Hard Case 69.5mm x 45.2mm x 24.0mm (7) ROAR
- LRP VTEC LiPo 5100 Competition 69mm x 44mm x 25mm 272g EFRA
- ProTek R/C 2S "Supreme Power" Li-Poly 35C 69mm x 47mm x 28mm ???g (3)
- Reedy LiPO 5100mAh 35C 69mm x 47mm x 28mm 327g ROAR
- Reedy LiPo 4200mAh 35C EFRA Spec 69mm x 47mm x 23.2mm 283g EFRA
- SMC 4900mAh 25C 67.5mm x 45.75mm x 25.5mm 290g ROAR
- SMC 4900mAh 25C 70mm x 46.5mm x 27.5mm >290g (2)
- SMC 5300mAh 40C 70mm x 46.5mm x 27.5mm >290g (COMING SOON) (6)
- Speed Passion Speed Power 4200 mAh 30C Saddle Pack 68.5mm x 46mm x 31mm ROAR EFRA
- Speed Passion Speed Power 5500 mAh 30C Saddle Pack 68.5mm x 46mm x 31mm ROAR
- Thunder Power 5400 Pro Race Saddle Pack (TP5400-2SPRS) 69mm x 46.5mm x 28mm (5) ROAR
- Trakpower TP3200 3200mAh 20C 71mm x 47mm x 22mm 204g (1) ROAR EFRA
- Trakpower TP4800 4800mAh 20C 70mm x 47mm x 30mm 252g (1) ROAR
- Vampire Racing 4400mAh 30C 68.5mm x 46.5mm x 23mm 225g EFRA
- Vampire Racing 6200mAh 30C 68.5mm x 46.5mm x 31mm 335g
SOFT-CASE
- MaxAmps 4400mAh 2S4P 25C 66mm x 34mm x 25mm 240g
- MaxAmps 5500mAh 2S5P 25C 66mm x 34mm x 31mm 295g
- MaxAmps 4000mAh 2S2P 30C 66mm x 34mm x 31mm 295g
- Reedy 4800mAh 20C 68mm x 44mm x 24mm 282g (4)
Hard Case
Fantom PRO RACING SERIES 5400mAh / 40C (L) 69mm (2.72 in.) x (W) 46.6mm (1.84 in.) x (H) 28.5mm (1.12 in.) x two cases
Why can't there be a standard size except for the height? There should be some kind of standard, it cannot be that hard to make a standard hardcase size.
BTW here are some sizes:
Intellect IP 4200mAh 30C - 69x46x23mm for each
Intellect IP 6000mAh 30C - 69x46x31mm for each
Hope this helps.
Hope this helps.
From: Conducting aggressive board meetings at my local track
HARD-CASE
SOFT-CASE
HARD-CASE
- Intellect IP 4200mAh 30C 69mm x 46mm x 23mm (user submitted)
- Intellect IP 6000mAh 30C 69mm x 46mm x 31mm (user submitted)
- Thunder Power 5400 Pro Race Saddle Pack 5400 mAh 69mm x 46.5mm x 28mm (I called them)
SOFT-CASE
- Reedy 4800mAh 20C 68mm x 44mm x 24mm 282g (via tower hobbies, no official data available)
