sc10 assembly question >
Old 04-08-2009, 08:38 PM
Default sc10 assembly question
So I'm putting my truck together and am having trouble getting the little wheel pin through the rear axle. How did some of you guys get yours in place?
karter15 is offline
Old 04-08-2009, 08:45 PM
xDaRReLLx87's Avatar
have you checked for any burs? Why proper technique of course. Is this on the yolk?
xDaRReLLx87 is offline
Old 04-08-2009, 08:56 PM
OTE_TheMissile's Avatar
...HUH?
I have a small pair of adjustable pliers with a notch cut into one of the jaws using a Dremel. The toughest part is getting the pin started, but once it's in the hole you can just clamp it down with the pliers and when it comes out the other side of the axle it'll pass into the notch.
OTE_TheMissile is offline
Old 04-08-2009, 09:04 PM
Originally Posted by OTE_TheMissile
...HUH?
Ball snap pliers they sell them. I was stating to be sure to check for burs for propper insert which is always a good idea when building a kit on any part your putting together. I didn't specify enough on last post evidently
http://www.amainhobbies.com/product_...ducts_id/12315
Old 04-08-2009, 09:08 PM
...HUH?
I was thinkin about doin that to my pliers. I got them started but they sure as hell aren't any easier to finish.
karter15 is offline
Old 04-08-2009, 09:11 PM
It is better to get the tool designed for the job, but all I do for inserting pins into the axle is I take needle nose and use the side (pivot point) as a hammer and I place the part I'm working on a flat level surface and softly hammer it in place.
I just drank some Nos so my brain is functioning you can probably tell
Old 04-08-2009, 09:26 PM
Suspended
The rolled pins can be difficult it install, run them for now but when you get the opportunity replace them with the solid pins. The rolled pins will break in time.
Wes Briscoe is offline
