SC10 Thread
Your right. The 16t pinion would make it more controllable. Heat is not an issue since its a four pole but at these speeds the wind could make it lose control. I can't even ease into full throttle. The wheels will break loose and want to get sideways. LOL its funny how these rcs draw an audience. I hit a squirrel LOL. It froze like a deer.
Avid steering rack
GH front Top plate
GH front bulkhead
FN Cuda front brace (extra not replacement)
Rear 0deg hubs
JConcepts Wheel nuts (for the locking not so much for the Al)
My truck felt much more stolid and responsive after doing all of those upgrades. It let me soften up the suspension a good bit where before I had everything really stiff to get the feel I wanted. Which led to better lap times.
SQUIRREL
im looking at putting a tekin redline 8.5 in my ft sc10 anyone have troubles with wearing out cvds or blowing the ball diff or transmission. putting this much power through the truck.
I've been running a 10.5 and 13.5 and I have problems with my CVD's/CVA's and out drives. Both of those wear the most for me. My diff's seem to last.
Suspended
I only ever ran a 6.5 in my SC10. I didn't have any premature part failures, or excessive wear. If you take your time, build everything correctly, and stay on top of the maintenance, you will be fine.
Not sure if anyone else has had this problem yet (I'm guessing I'm not the only one) but I noticed my FT carbon top plate wasn't holding the skid plate screws in and they weren't tightening down as tight. Solution? 4-40 helicoils! Now I don't have to worry about them backing out but if they do, I can put some blue loctite on them
I'm guessing I'll need to install these in various areas of the truck as time goes on.
I just posted this in the FS section. We are doing a fund raiser to help raise funds for out Cars -4- Kids RC Program.
Screw kits for the B4/T4/SC10.
http://www.rctech.net/forum/r-c-item...nd-raiser.html
Thanks,
Vince
Thanks,
Vince
I'm guessing I'll need to install these in various areas of the truck as time goes on.Tech Master
AVID Big Bore Spring sets are available.
AVID Springs
Anyone have any luck with the pre-release and a certain setup that's right for your track?
AVID Springs
AVID Springs
AVID Springs
Qustion for the guys running 7.5-8.5 turn motors. How are your weights set up? I just upgraded from a 10.5 to an 8.5 and need a little more rear bite. With the 10.5 I was running 2 and a 1/4 oz behind the rear battery foam with the battery placement in the center of the tray. Just looking for suggestions.
I almost run that much with my 10.5 and 13.5.
