HoBao Hyper 9E thread
#1381
YEH I HAD THAT PROBLEM WITH THE TEKIN IN SENSORED MODE THE WHEELS WAS SPINNING THE WRONG WAY, IS THERE ANY OTHER WAY AROUND IT . IM RUNNING THE HOBBY WING 150A
#1383
http://www.hobbyking.com/hobbyking/s...dProduct=10869
They should have enough juice to get you through.
Or you could try this one, if you need a little more power (though it has a lower C rating):
http://www.hobbyking.com/hobbyking/s...5C_Lipoly_Pack
Finally, though they might not be the best fit possible (they will stick up out of the battery tray and possibly touch the body), a pair of these wired in series would probably give you the best runtime:
http://www.hobbyking.com/hobbyking/s..._Car_Lipo_Pack
#1384
If your mains are 15 minutes or less, go with these:
#1385
Has anybody tried these wider offset wheel hubs? Do they stay snug and tight? Do they give the buggy a wider wheelbase?
http://www.nitrohouse.com/catalog/pr...ducts_id=10539
#1386
imo flipping the diffs is better than setting the esc to run in reverse rotation.... dremel the bumps off the bulkheads
#1388
So if you swap the diffs, you have to dremel the bumps? Do you have any pics of this?
#1389
The whole mod took me about 15 minutes, tops.
#1394
