Old 12-02-2003, 03:05 AM   #1
dragster's Avatar
Unhappy 27T Stock gear ratio?
Hi, need help to find a baseline ratio to start of with, Losi xxx 27T core stock, using around 7.9 to 8.3 ratio, need all the info & help i can get.
dragster is offline   Reply With Quote
Old 12-02-2003, 06:15 PM   #2
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
There Should be a Gearing Chart in the Manual...
LosiFromHell986 is offline   Reply With Quote
Old 12-07-2003, 08:59 AM   #3
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
On the Core and a XXX.What color spur are you using and is this for offroad or something else?
Most guys gear it 82/21 or so here in the states with a 100 ft straightaway.I would try 20-22.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 12-08-2003, 11:38 AM   #4
treky11's Avatar
depending on the track. but i have run the stock white spur with a 21-22 pinion and a 82t yellow spur with a 20-21. both using either a trinity monster or p2k motor.
treky11 is offline   Reply With Quote
Old 12-08-2003, 11:41 AM   #5
Being EVERY motor is different even when in the same can,same brushes and same springs all motor's have a SWEET spot.
I usually leave my spur gear off and run a 20 for 2 laps,then reset it for a 21 and then a 22.See which one gives you good top end and good punch as well.
The Core motor's are Wonderful for offroad buggy and truck.
I would do 82/21-22 or 84/21-22.See what works for you.
Old 12-09-2003, 03:12 AM   #6
dragster's Avatar
I have been racing xxx off road for under 1 year, started with
78 or 82 spur, 23 to 25 pinion, main stright is 80ft track is tight with lots of jumps, will try 20-22 pinion this weekend: Also will try 84 spur & see how that goes, 80 % of the racers at my local R/C track are using monster stock, they do have more top end speed than any other stock motor
Old 12-09-2003, 07:17 AM   #7
Yea but straighaways isnt what wins races.
If you take the infield and make it one length it will be 3 times longer than the straight.So if you can HANG on the straight then you will kill them in the infield.Cool thing about Cores is they handle heat and Abuse ALOT more than Trinity Motor's do.Quality of magnets are ALOT higher.
Try factory springs with Reedy 767 brushes and gear it 82/21-22 and see what you think against monsters in offroad.
Goodluck.
Old 12-09-2003, 07:18 AM   #8
PS.If track is tight and straight is 80ft.A monster shouldnt have ANY advantage over you.Now driving wise they might but if you have a decent esc and decent batteries you should be fine with the core.
pan car gear ratio joe of loath Electric On-Road 2 04-03-2008 10:13 AM
Gear Ratio Help James605 Electric On-Road 2 01-20-2006 11:46 AM
gear ratio Franky Australian Racing 2 01-15-2004 12:51 AM
Stock gear ratio on e-maxx? seriousre Monster Trucks 2 10-04-2003 09:56 PM
gear ratio.. TRF_TG10R Nitro On-Road 0 08-06-2003 05:18 PM
