Old 03-29-2009, 09:16 AM   #1
Dookiman's Avatar
Default Losi conversion kit plastic spur rubbing....??
Just got my losi converstion kit and was building it up. I mounted the plastic spur gear to the center diff. When I reinstalled into the diff mount the spur gear rubs on the diff/motor mount something fierce!
I tried to shim it but that did not work...What am I doing wrong?
Thanks!!
You gotta love it...
Losi/Werks Racing/AKA/Fastlane Graphix
Dookiman is offline   Reply With Quote
Old 03-29-2009, 11:43 AM   #2
Trader Rating: 42 (100%+)
built mine last nite and it's doing the same thing. Even to the point of not turning at all unless pushed by finger.
Puddin
475 Designs, Team Sweeno
B&L Hobbies/Smac Track
pq49x is offline   Reply With Quote
Old 03-29-2009, 11:48 AM   #3
Got a little Captain in ya??
Gilley11's Avatar
Trader Rating: 15 (100%+)
I just did a conversion as well and yes mine rubbed hard on chassis. just remove some material under it and it's good now. I took a 3/8 drill bit and drilled 3 almost holes not thru the chassis. Then clean between them with dremel. I took it apart 5 times and could not find anything else but that so it was the fix for me
Gilley11 is offline   Reply With Quote
Old 03-29-2009, 03:17 PM   #4
Installed my kit on truggy and no rubbing
TomG2762 is offline   Reply With Quote
Old 03-29-2009, 04:48 PM   #5
Gilley11's Avatar
metal spur or plastic??????
Old 03-29-2009, 04:49 PM   #6
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
With the plastic you have to dremel the spur gear cover a bit, it's normal. Just takes a couple of minutes.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 03-30-2009, 01:47 AM   #7
Dookiman's Avatar
I put shims behind the bearing. This freed the spur from rubbing on the diff/motor mount. It still rubbs on the plastic spur cover and it sits directly on the chassis.
I will dremel the plastic cover out. But, I think I will raise the diff mounts with shims before I drill out the chassis.
I just think Losi could have put this in the directions some how though...????
Old 03-30-2009, 08:19 AM   #8
XXXDad's Avatar
Trader Rating: 195 (100%+)
SORRY GUYS... I'M A LOSI GUY BUT WHAT CAR IS THIS FOR AND WHY? I'M LOST!
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 03-30-2009, 12:21 PM   #9
SpeedTech's Avatar
I added a .3mm shim behind the bearing and the problem was solved.
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 03-30-2009, 01:13 PM   #10
Gilley11's Avatar
I agree the directions were less than helpful
I've read that when you shim it up screw lenght is an issue and most important that you put (bind) on diffs or rubbing issues on radio tray.
Not that it's wrong just check for these issues.
There's nothing like staring at that sheet of paper flippin it over every two minuites look for a better view or directions
Old 03-30-2009, 05:23 PM   #11
Trader Rating: 11 (92%+)
i put a shim on and now the diff mounts/motor mounts wont line up with the chassis...this is getting agrevating
Team Losi:
XXX-CR w/ LRP Sphere 7.5
Brushless 8ight w/ Mamba Monster v3
losiracer18 is offline   Reply With Quote
Old 03-31-2009, 01:06 AM   #12
Dookiman's Avatar
This thread is refering to problems with the fit of the plastic spur gear supplied with the Losi electric conversion kit for the 8ight B and T.
Old 03-31-2009, 05:38 PM   #13
after some dremeling the spur gear doenst rub....kind of. Oh well its better though spins freely
Team Losi:
