Old 02-03-2009, 10:00 AM   #1
maylemay's Avatar
Default Need help
I have a rustler XL-5 and I was bashing it in the street. I was not running it very hard and after about 5 minutes I herd a kinda squealing noise I figured out that it was coming out of the main gear box but I dont want to take the time to open it up and not know what happend so if any of you had this happen to you please let me know what you did to fix it
maylemay is offline   Reply With Quote
Old 02-03-2009, 10:16 AM   #2
Chimer's Avatar
Trader Rating: 26 (100%+)
I never owned a Rustler, but I have had a sqeuling noise before.
Check to see if your slipper is adjusted properly and check that the wheels turn without making any crunching noises in the gear box. It could be a bad bearing also.
Ultimately, I would not be lazy and take the gear box apart to inspect everything. Check all of the gears and bearings. Also check out the motor and clean it. Check the wheel bearings too. Bearings may need to be cleaned and re-lubed or it could be too late for that and you may need new ones.
Doing maintenance is part of the hobby. Your Rustler will last longer, go faster, and handle better if it is properly maintained. The instruction manual that came with your Rustler should be a huge help to you-check it out!
Chimer is offline   Reply With Quote
Old 02-03-2009, 10:17 AM   #3
Suspended
you are going to have to take the time, because without some self diagnosis on your part all anyone is doing is guessing since it could be a ton of things. welcome to the wonderful world of RC
RobbieT is offline   Reply With Quote
Old 02-03-2009, 10:35 AM   #4
maylemay's Avatar
thanks
Logan Off Road ( The Brickyard ) Brisbane QLD BIG O Australian Racing 10325 03-08-2017 04:07 PM
SC10 Brushed motor need help! dsl Electric Off-Road 12 08-11-2009 10:19 AM
ARIZONA TOURING CAR RACERS rcracerdude Racing Forum 6536 03-06-2008 04:21 PM
cheep esc descision... Johnathan Rookie Zone 8 07-23-2006 02:42 PM
Need Help! Car Glitching!! MugenMTX3Kid Electric On-Road 47 02-28-2004 03:27 PM
