ae 12mm springs?
ae 12mm springs?
whats the difference in these besides lengths ? Why would you run one or the other different lengths?
12mm Front SPRING BRN 2.85
12mm Front SPRING BLK 3.00
12mm Front SPRING GRN 3.15
12mm Front SPRING WHT 3.30
12mm Front SPRING GRY 3.45
12mm Front SPRING BLU 3.60
12mm Front SPRING YLW 3.75
12mm Front SPRING RED 3.90
12mm Front SPRING ORN 4.05
12mm Front SPRING PRL 4.20
12mm Rear SPRING BLK 1.90
12mm Rear SPRING GRN 2.00
12mm Rear SPRING WHT 2.10
12mm Rear SPRING GRY 2.20
12mm Rear SPRING BLU 2.30
12mm Rear SPRING YLW 2.40
12mm Front Spring (54mm) GRN 3.75
12mm Front Spring (54mm) WHT 4.10
12mm Front Spring (54mm) GRY 4.45
12mm Rear Spring (72mm) GRN 2.20
12mm Rear Spring (72mm) WHT 2.40
12mm Rear Spring (72mm) GRY 2.6
Those are the spring rates. The higher the number, the harder the spring. Fronts are 2", rear 2.5". Gray fronts and white rears are a good starting point for an SC5M. Also note that you want truck springs, not buggy springs. We're currently running AE gray fronts andKyosho gold rears on the SCX
I think the 91637s are the most current version. That's what we run on the front. Fewer windings like the Kyoshos. Though they are listed as compatible, I think the 91329 was developed for the V1 big bore shocks starting with the 4 series platform. To make sure I'm not in error, you may want to check the SC5M thread. But it's a really big thread so it may take a while. I just want to make sure the info I gave you is correct
SPRINGS: 12 mm.
With a shorter spring,you may run out of room to correct your ride height.
I had to go with HPI purple on my E maxx(8 rear shocks).
Thanks for that post!
I didn't know that AE made a purple rate spring for the front!
I may need these.
*************Off topic*****************
Those may work for carpet trucks,but I don't run on carpet anymore.
I had to use reds and greens on the front to take away the steering and traction roll issues.(I could have used sedan springs)
I may need these.
Part of the reason we have Kyosho springs on the rear. Drilled 2 new holes about 1/4" inside and down of the original ones on the XFactory rear tower. Laid the shocks down and used the #1 hole on the arms. Great side bite, but had the preload collars near the end of the threads. The Golds are about 1/4" longer and slightly stiffer (Dammit Kyosho, you use the best springs but don't give rates for any of them) so the rear still comes down softly off the jumps.
The 54mm/72mm springs are the "truck" springs. They are longer and more progressive. IME, they work better with the longer shocks on trucks. I actually run them on TLR SCT shocks on my Slash, lol.
