Weird noise when breaking
When i break i hear this noise kind of like metal scraping or something what is this and how do i fix it ?
its in my b4 i think it has something to do with the differential. And when i mean "Break" i mean the breaks that you use to stop the car not literally breaking the car.
Which one do you use to upset people sszzxx?
You should start braking before you keep breaking
Check your rear bearings and make sure you lube your rear CVD's (if you have them)
2 people using the same computer you caught me!!!! forgot to log out anyways i dont have cvd's. should i just rebuild the diff, did tigthening it to much wear down the balls causing the noise?
Do you hear the same noise when you are accelerating? I would be surprised if it is your diff if only on braking.
A few things to try
1 - Check that your motor screws are tight and that the motor isn't moving when you brake.
2 - Take the pinion gear off and make sure the drivetrain moves freely in both directions
3 - If this is a brushed motor do a test with the pinion gear off on the workbench ad see if the motor is making the sound.
A few things to try
