Losi 1/8 8ight E 4wd Thread
#7336
dangerwr
hey how tight do u set the gear mesh
#7337
You can set gear mesh a little tighter with the plastic spur. I set mine to where I can barely hear a little "click" when holding the pinion with one hand and moving the center diff back and forth with the other. Make sense? Some people say place two pieces of paper but have never tried that trick. I just use my calibrated ear.
#7338
im using the carbon fiber shock towers from matrix rc and i haven't broken one in 2 years of racing and bashing, im sure that my very flexible chassis and rear flex brace helps to absorb the energy from impacts, on bad landings, it bounces like a basket ball
#7340
hi i m new to offroad from onroad
and i got a 8ight conversion to electric
that come with center smart diff.
just wondering is the smart diff useful?
anything i need to pay attention to?
thanks for any help in advance
#7341
I personally like how it works through tight turns off power as well. The transition from power on/off is not as smooth (as standard diffs) but is quite predictable in my car. Cheers!
#7342
I think I read somewhere on this long thread that the motor support is not necessary, and could cause problems by changing the pinion and spur mesh. Do a lot of you guys not run the motor support? Is the motor mount strong enough without the support? I've got some huge jumps on my track and I'm a bit worried the motor mount won't be strong enough without the support.
#7343
The mount is More than Strong enough.
#7345
Wing: Stock & Upgrade Vortex
Body: Stock or Pro-Line Slipsteam
I have been told the stock wing is one of the best designs on the market. The stock body has been the most durable. Not great on looks and is why I run the Slipstream which has been discontinued for some reason but they are out there online. The JConcepts is really cool but cracked and fell apart on me quite easy and I use Shoo-Goo on all my bodies.
#7346
#7347
Stock Wing
Proline Bulldog Body
Attachment 915565
I cut the body pass the cut line as you can see in the pic. helps clear the battery.
Attachment 915565
#7348
No idea... never tried it
#7350
