Losi 1/8 8ight E 4wd Thread
#6181
if anyone is looking to do a electric conversion i have a Losi 2.0 buggy that will be perfect for it. its wore out but still usable. it has the old style adjustable hinge pin brace on the rear, stock up front. no body, fuel tank, radio tray or linkage. it would be complete tho if you bought the electric conversion from losi tho. 100$ + shipping PM ME
#6182
yes i have a spacer for you. BTW what hinge pin braces are you running, the adjustable or stock?? if you want i have a brand new set of the stock i pulled off my buggy you can have. also PM me what you are looking for i might be able to help you out. i have some old parts i can give you.
#6184
does anyone know what the difference is between the 8ight E and 8ight E 2.0 front arms? They have different part #'s but look exactly the same (from the pics I have seen).
#6186
thread?
does this thread count as a losi 8ight E 2.0 thread also? Or is there another official thread for the 2.0
#6188
ok thanks ^ um it annoys me that rctech does not have a quick reply section in threads
#6189
Well, I am out of town for the week and went to a local hobby store. I bought some front arms (part LOSA1700) for an "8B". I didnt think about the fact that there was an earlier version of this buggy (i was thinking gas version and E version being the same so I picked them up). I can still take them back but they sure look the same as the 2.0 arms.
http://www.losipartshouse.com/servle...ion-Arm/Detail
#6190
#6191
#6192
so i have an issue,
i received my protek 5600/50c batteries today and i think they are to tall. the battery straps barley overlap like a couple mm and im having to pull tight to get that. I am worried about my body fitting if im having such a hard time with the straps. What are you guys doing?
#6193
My proteks fit just fine, I'm using the Losi E body and I mount my straps unconventionally. I put the non buckle end up through the outside battery tray slot then over the battery, down through the inside slot and pull tight and the Velcro meets up great. I've even cut off some of the strap as it was too long. Hopefully that will work for you.
#6194
