hinge pins TI vs SS >
hinge pins TI vs SS
hinge pins TI vs SS
Old 08-25-2003, 10:55 AM
corvettecrazy's Avatar
Default hinge pins TI vs SS
what is better stainless steel hinge pins or titanium??
will both work if later I upgrade to AL a arms??
this is on a HPI nitro MT
corvettecrazy is offline
Old 08-25-2003, 02:51 PM
anyone???? i need the info today!!
thanks
Old 08-25-2003, 03:15 PM
SlobbaTech's Avatar
Stainless is heavier than steel, titanium is lightest and strongest but titanium has a rougher surface which will wear on your parts more and the suspension will not be as free or smooth. Stainless is weaker than steel, it sounds like you'll just be bashing around most of the time so I'd say get titanium b/c they are stronger. If you have steel ones in there now you can just chuck them into a dremel and polish them unless if they are bent, nothing wrong with the steel pins and not really needed unless you bend them or can't find better spots to take weight off of a car.
SlobbaTech is offline
Old 08-25-2003, 03:24 PM
does titanium bond to aluminum?
i would stick with stock BUT in the rear they use screws and they wont stay in so my solution to not have to worry about it and have sus. that moves more freely is to put some hinge pins in.
