x60 truck
is this kit out yet from xfactory? im wanting to convert the t4 to it..
I heard maybe September.
Brian, Paul, and Alex will have the latest prototype parts on their trucks at the Shoot-Out. If all goes well there, we're ready to start making the molds. Still hoping for sometime in September.
Will the conversion only be for the T4 or can you convert a XXX-T also?
Originally Posted by jjdoyle
(Post 4584863)
Will the X-60 be similar to Kinwald's X-60 or the other few driven by the X-Factory guys? Just curious because Kinwald's seems to have a lot of Losi parts, such as shocks and front arms... which means there's probably some more losi parts then just that.
The X-60 will be T4 based.
What you saw on Brian's truck was just Brian trying things. He does that. You can fit anything with time and a Dremel. :D Don't forget, what you see until the actual kit is in the box are just working prototypes. At times, you may see odd things on them. We try things to see what they will do. My X-60 has a rather interesting shock setup on it. It will never make production but it was fun seeing what it would do. |
Originally Posted by SpeedyDad
(Post 4592217)
will it have the four gear trans? any other special goodies? :sneaky:
Originally Posted by strodedawg
(Post 4593136)
As far as other goodies, wait and see. |
Redrc says they are close to production.
http://www.redrc.net/2008/08/x-facto...se-to-release/ Chad O |
Soon my friends, soon
the x-60 maybe the only thing that will get me to switch from my j82.does anybody know if the associated qc hubs and wheels will work?
Originally Posted by DRKSYDE
(Post 4745957)
u
looks cool something different
r u guys using the x/6 chassis
The X-60 uses a longer chassis than the X-6
when will i be able to buy one
(Post 4592217)
(Post 4746142)
I'm running them on my X-60 currently
Originally Posted by porkey
(Post 4806036)
Originally Posted by Chris__RC
(Post 4806059)
What shock setup is it?
Originally Posted by crazyjr
(Post 4806128)
The QC question was going to be my first one thanks. Question 2, If converted, will you be able to go back to stock? Here in Ga. we got varying track conditions, and it might be better to go back to stock. I could get a second T4 to leave stock if i needed.
How about some clear and detailed pics since the kit has already raced at some major events... it certainly can't hurt especially if you mention any needed disclaimers.... :tire: :nod: :tire: |
The true kit has not raced at any races yet. All the trucks that have been raced are hand-built prototypes built by myself and Brian Kinwald. The only pre-production actual molded parts completed so far are the rear arms.
We'll get more pics out when we get closer. The production chassis will be a little different than the pics that have been posted so far. Be patient. Work is being done as fast as can be. |
Chazz took quite a few detail pics at the Nat's of our trucks, hopefully those can be posted when we get our galleries up.
Crazyjr - yes, as SpeedyDad said you'll be able to convert back without a problem, though given it is a chassis change it wouldn't be something I'd want to try at a track. What kind of conditions are you worried about? I've been running my X - 60 at a blown-out gas track here in Nashville with really good results. |
Originally Posted by Paul_Sinclair
(Post 4806794)
Michigan has a ton of loose dirt, blown out tracks and the X-60 has been doing really well on them. I'm running the shocks of my GT with the same pistons/oil/springs and I haven't seen a reason to make a change yet. The 4-gear trans and the mid-motor positioning makes for a heck of a truck.
(Post 4806794)
Chazz took quite a few detail pics at the Nat's of our trucks, hopefully those can be posted when we get our galleries up. |
X-60
I have driven Speedy Dads X-60 here locally and i like the way it feels over my T4, My home track is SRS the home of the Cactus Classic, Even the first version that i drove. It seem to handle better than a T4, but it also depends on your diving style, It seem to be able to dive into the corners better. Dont get me wrong i love my T4FT but this could give the X-Factory line the push it needs to put more kits on the Podium.
P.S. Good work on the X-60 Speedy Dad. See you and Penquin Back at SRS after States.:D:D |
Thanks Cowboy. See you after States.
all i know i built 2 from the x-6 kit 4 chassis for indoor offroad carpet racing it rock
tq with them. when they come out i`m going to get two of them i will be going to the crcrc race in jan. can`t wait to meet you speed dad what the height of the rear shock tower i have been using b4 rear shock on my rick seffrood |
Originally Posted by gone banana
(Post 4826057)
i have been using b4 rear shock on my |
At Hot Rod's, Paul was running a custom rear tower on his truck. As it turned out, the hole he ended up using on his corresponds to the 2nd hole on the buggy carbon fiber tower, which is what I'm using on mine.
Originally Posted by scrubnick
(Post 4828572)
3 Attachment(s)
Here's some pics of mine:
my x-60
:sneaky::sneaky::sneaky:
my 2 x-60 for indoor carpet
Anyone planning on doing an X-60 with a J82?
Originally Posted by BobWoodhouse
(Post 4834320)
