Team Losi XXX Kinwald Edition Same as new ones??
Hey guys... I have been out of the loop for a few years on the R/C cars. I moved and never unpackaged all of my stuff. I have 2 Kinwald Edition 1/10th scale buggies and the truck as well. I was wondering how much these have changed compared to the modern ones of today? Big differences? I just pulled them out today and minus a few batteries being a little messed up 2 of the cars are working no problem and the other I just need a servo for. Well, thats it for now and if I have any more questions I will ask! Thanks in advance!!
do you have the first losi xxx or the xxx bk2 with the different transmission? either one is still good and competitive and either could get into the a main with a good driver. also the old losi graphite is super strong, way stronger then any of the plastics current cars are made from.
The actual geometry is pretty similar. There is a newer material (ea3) that is cheaper, flexes more, and gives the car a little more traction. The rear end has changed around a little bit, a wider pivot and shorter arms along with vla (coming from the bk2 car) front and rear. Theres also a steering rack that changes the ackerman up front.
new parts compared to your car:
front shock tower, front arms/hubs, steering rack
new rear pivot, rear arms/hubs, rear shock tower
the rest would just be buying new ea3 plastic stuff, but that doesn't change the geometry at all.
Awesome! I don't think I will ever really be too competitive with the r/c cars anymore... I don't have time for it! Haha. I race motocross right now and one of the tracks I go to has an outdoor R/C track. It is pretty cool and it reminded me of my cars, so I dug them out today and everything actually works! I think I just have to get some new batteries and I am good to go. It would be fun to play around with while I am taking a break in between motos.
get a good lipo battery and lipo charger and you can run em for a lot longer than you used to! we're talkin 15 to 20 minutes easy with stock and mild modified motors.
If you go to a brushless motor and speed control as well, you won't have to worry about anything electric EVER!
Technology is your friend.
RC has never been better.
Hahaha. I'm sure crashing the buggy is a lot more fun than missing a triple yourself... I would bet a lot of money on that one! I was wondering if they had lithium batteries for these things yet. I have a combat wing that I run a lithium battery on. How much do those things run?!? Also, I have a couple Novak Millenium Pro chargers... will they charge lithium? I don't think they do. Are they still a good charger? Thanks for the replies!!
yeah definitly agree with the missing the tripple while your on a bike
Losi makes the Lipo converter for the Millennium Pro's, part number LOSB9607.
losi
get a b4, i spent 2 years fooling with these cars, dremeling parts, making old rear ends fit on the car, ect..
No, they won't charge LiPo's without a converter, but they are still one of the best chargers out there for Nickel Metals and NiCD's, that's what i use for my NiMH's. I've had one of my Millennium Pro's since 2002, and it still works flawlessly.
I'm not going to get a new car because as I said before I will just be doing this to mess around now. I don't think I will be competitively racing R/C cars again any time soon. Maybe in a few years again, or if I totally get hooked... but as for now I will just use what I have, because they really don't seem TOO far behind the times. I also have an Airtronics M8 controller, which still seems to be pretty decent. Everything I have is totally mint and barely used.
If you're not racing, just run what you have. Heck, I'm racing a XXX-BK now!
As for the battery, it'll take several cycles to "bring them back," and even then they might now come back all the way. I'm no expert, but I've been able to bring back some dead nimh batteries by continuously charging until they are warm (~125 degrees) and discharge and repeat. Good luck!
Hmmm... I will try, but the Novak Mil. Pro automatically stops itself every time. It is like a built in safety mechanism or something... any way to bypass that or do I need to dig out the older chargers??
I had some nimh batteries that would false peak every 4-5 minutes. I would just unplug the battery, replug it, and charge again. I kept doing this until the battery was warm (fully charged). Then I discharged it. It was a pain, but after a few cycles, the battery seemed to take a charge better and false peak a lot less. Again, I'm not an expert, YMMV...
