Originally Posted by Dave H
(Post 4212056)
It seems you are saying that the sparks are from the bannana connectors, not the batteries themselves, then I suspect the connectors are not making good contact. Not cell venting.
Are the connectors getting warm/hot? If so, it seems that they are warming up, and thus expanding slightly. Towards the end they expand enough that ya start losing contact, then the sparks start. Low budget fix, crimp the connectors with pliers some to get a better contact. Better, new connectors. Good Luck. |
to if u want I'll take a look at them on fro if your down
Originally Posted by BSS07
(Post 4211347)
haha but evan also said something about venting when i asked him, like the battery's were realsing energy or something like that....
hes even the size of a Sub C:lol::lol::lol::lol: |
Originally Posted by li racer
(Post 4214646)
Evan is the product of venting gone wrong
hes even the size of a Sub C:lol::lol::lol::lol: lol |
if you have the battery bars bent 90 degrees and have them laying against the side of the cell they could have rubbed through the shrink wrap and contacting the can.
i know i had to have some of my battery connectors like this for my jrxs and accidentally had one go through and had a cell overheat from shorting. |
Originally Posted by chewiefttc4
(Post 4214708)
i know i had to have some of my battery connectors like this for my jrxs and accidentally had one go through and had a cell overheat from shorting. Yea, he is right. You must always make sure those bars are positioned away from the outside of the cells. |
if you must have them laying against the can heatshrink them..
use appropriate colors so you dont accidentally reverse the polarity. the heatshrink will also protect from rubbing through |
I would not trust Banana plugs myself because they might compress.I would use sermos connectors if it were me they also go by duratrax powerpole and lite speed.If you are racing that the way to go and even if you are not,why not if you are great run times on your packs.they are better than Tamiya plugs witch can melt,I've never used anything but sermos and never a problem never seen one melt can not say enough good stuff about them.They are like deans or Tamiya plugs where you have a male and female plug these are unisex,also another good thing is that the way they go together you can slide them so when put together they are sitting one on top of the other or side by side.The benefit to this is if you use a wire lead on your motor with a plug on the end of it so you can make motor changes easier is that because if you slide the plug's together one on top of the other on the power out side of your ESC you will not be able to plug the motor to the power in side of the ESC if you put the power in side plug's and your battery packs side by side.The other thing I alway's ask if someone want's to know what a good battery plug is do you have a local hobby shop close by if they say no then I will alway's tell them to use these and get a few extras,because it sucks for example if you use deans plugs and you need a new one and it is a male your needing and you olny have a female in your spare part's box that is now a thing of the past with these because they are unisex you will know if you have a spare sermos it will always work and they will not compress and come lose,but that's just my opinion.
not sure what car he is running those packs in. but some touring cars require those type of connectors or even direct soldering.
