Old 02-12-2008, 01:03 AM   #1
Default Opinions on these inexpensive LiPo packs?
http://cgi.ebay.com/11-1V-12C-5000mA...QQcmdZViewItem
My sons have BL Rustys. I am in need of buying MULTIPLE batteries for them. Since they are only bashers and I will need a number of packs, I am not interested in spending big money.
I think these LiPo packs, even though they are not top of the line, should easily out perform any NiMh pack.
As long as I can feel SAFE allowing my sons to run these packs, I think it might be a good bargain. BTW, charging is my responsibility regardless of pack chemistry.
Opinions?
wevie is offline   Reply With Quote
Old 02-12-2008, 06:14 AM   #2
Alltapdout's Avatar
You get what you pay for.
Alltapdout is offline   Reply With Quote
Old 02-12-2008, 06:19 AM   #3
SQC049's Avatar
Trader Rating: 16 (100%+)
Hope you have good homeowners insurance.
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
Old 02-12-2008, 08:33 AM   #4
Send a message via AIM to GroffBall
The maxamps packs seem fine. Why not just get them each one high capacity lipo pack like a 6000mah that should keep them running for a half hour more than likely. I wouldn't waste my hard earned money on any lipo battery that isn't proven to work.
GroffBall is offline   Reply With Quote
Old 02-12-2008, 09:04 AM   #5
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
+1. Although they may be perfectly fine, when something does go wrong with a LiPo pack, it can be quite dangerous.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 02-12-2008, 09:49 AM   #6
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
+1
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 02-12-2008, 04:06 PM   #7
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
I think that any lipo that HAS been approved by ROAR is one to get
ROAR will under go a great amount of testing to approve a pack
Any pack not approved means it is not a safe pack!!
imo
Crazy Carl is offline   Reply With Quote
Old 02-12-2008, 05:21 PM   #8
Trader Rating: 73 (100%+)
imo
I wouldn't go that far. Manufacturers have to pay ROAR to approve a specific pack. Do you think because someone won't pay a racing organization a testing fee that the pack is unsafe? Heck no!
skelly1344 is offline   Reply With Quote
Old 02-12-2008, 05:23 PM   #9
Trader Rating: 23 (100%+)
a little iffy there could be better
not home is offline   Reply With Quote
Old 02-12-2008, 05:51 PM   #10
Crazy Carl's Avatar
If they dont have any worries about there product. But if the do, then the excuse that you posed will be what will be used
Old 02-12-2008, 06:20 PM   #11
MitchellB.'s Avatar
I would suggest you not buy those. 12C? Are you serious?
Mitchell Bumgardner
Bumps and Jumps RC Speedway
Team Novak
Futaba
B44
XXX-CR
MitchellB. is offline   Reply With Quote
Old 02-12-2008, 08:10 PM   #12
So just to prove they have a good product, they should pay ROAR to say so? That's assinine.
If a manufacturer has no intention of selling a product to the racing community, there simply is no point in having any affiliation with ROAR or their testing. That has absolutely no bearing on whether that product is safe or not.
Old 02-12-2008, 08:19 PM   #13
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Wevie and Felow R/C Car Racers and Bashers
ATTENTION
MitchellB. is correct.
12C is a NO NO for racing and EXPECIALLY bashing. In racing we usually race for 5-10 minutes at the most.
Bashers are actually HARDER on these packs than even racers. Running full out for 10-20 minutes at a time on cement where there is no give.
12C rating is not very good. Maybe with a stock motor and limited to 8 minutes of runtime.
YOU WANT a rating of 20C,22C,25C
Hope this helps.
Les
TexRacer is offline   Reply With Quote
Old 02-12-2008, 08:42 PM   #14
ATTENTION
Hope this helps.
Les
There's always an exception though. A higher capacity pack, such as an older Maxamps 8000mAh pack used to have a 12C rating. With a pack of that capacity, 12C is no problem at all.
However, you are correct, 20C should be a standard minimum for anyone buying packs to bash with. The problem is that there is no standard between lipo manufacturers as to how bad the cells sag at that C rating. For instance, one manufacturers cells may remain at 3.6v/cell, while another unscrupulous manufacturer may have cells drop to 3.0v/cell or even lower at their C rating. My recommendation is simply to stick with well known pack manufacturers or companies using cells specifically from Enerland or Kokam.
And since I completely went around the topic in my last couple of posts in this thread...if you want to buy Lipos for your sons' Rustlers and not spend big money, Maxamps is about the only company I would trust. Even then, you'll need to unload your wallet a bit if you plan on buying 3S packs. Their most inexpensive 3S Lipo for a VXL is $115. Outside of them, I'd highly suggest the packs due out soon from Trakpower...a 3S 5400mAh hard case Lipo specifically for the VXL vehicles. The only drawback most will see...the cost of $170/pack.
That being said, unless your sons are really good drivers or you don't mind them breaking a lot of parts, I highly suggest 2S packs instead of 3S. A stock VXL Rustler on 2S Lipo will do 40mph out of the box. That's more than enough speed for most anyone bashing, especially kids. If you have any specific questions regarding batteries for the VXL's, I'll be glad to answer anything I can. I have 2 VXL Rustlers and a VXL Stampede myself and they get run on nothing but Lipo.
Old 02-12-2008, 11:21 PM   #15
Well, if the 12C rating and the low cost seem to lean towards the unsafe side, I definitely will NOT be buying them. MAXAMPS it is.
inexpensive lipo charger mduncan31 Electric Off-Road 9 07-10-2008 04:09 PM
LiPo Brand Opinions bprocket Rookie Zone 5 05-09-2008 11:01 AM
Maxamps lipo and DN Power lipo packs harjo R/C Items: For Sale/Trade 2 12-02-2007 11:20 AM
BEST LIPO CHARGER and LIPO PACKS GSP Electric On-Road 28 06-18-2007 06:48 PM
Need Opinions on Tuning My NTC3! opinions on my clutch/suspenion set up needed JDMboy Nitro On-Road 0 09-21-2004 10:05 PM
