Tamiya DB-01 Durga. The next budget racer?
#436
regarding the diff assembly ,from witch side you insert the screw and trust bearing?
from the short or the long diff joint?
thank you
thank you
#437
The thrust bearing goes into the shorter half of the Diff joint.
#438
Does anyone know the caster angle of the front hubs?
#439
what pinion should i use with a 5.5BL motor?
any suggestions?
thank you
Salvo
any suggestions?
thank you
Salvo
#443
I didnt know I can adjust the front hub caster via a certain 3 holes.
Maybe I can play with the shims below the suspension mount (the triangle shape thingee) to get different caster angles.. but that also change the arm angle.. giving it a certain kick-up angle.
#444
#446
hubs on the 501X and Durga have always been 10degrees - plastic or alloy - it's just that the alloy actually state what caster it is where the plastic don't.
#447
Thanks guys..
#448
c/f upgrades + centre one way
Has anyone else upgraded their DB01 to c/f reinforced chassis, diff and spur covers and centre one way ? I only tested for a few laps (forgot my charger)but found the centre one way does a great job...it engages alot more predictably than the front one way (which I found too quirky and went back to the diff).
On the handeling side the c/f chassis/gear covers make it a little bit more responsive...needed more laps to test
#449
nice to see some tamiya folks on here
#450
I race on very slick, loose surfaces. I'm pretty sure that I will be better off with the extra flex that is in the stock plastic chassis & gear covers. Most everybody changes out the graphite chassis on the Associated Factory Team RC10B4 buggies with the plastic one to get some flex for slick surfaces. I do want to get some of the thinner graphite shock towers though.
