Team Losi XXX-T CR, What are yours opinions ?
#151
I ran the truck this weekend. The track is an medium bite clay.
I was struggling for rear traction all night. I have the truck set with the wide s\u on the arms,long rear camber links w\2 washers,pink springs, black pistons 20wt,tower 3 hole out,out on arm (rear) black pistins, 25wt.,orange 2 hole out on tower, inside on arm. Dir ribs and tapers (pink) Still loose in the caboose!
#153
Is anyone running an Orion/Peak 4800 with XXX-T CR? Are you adding weight? Where?
Anyone else having issues with gearing? I have a Mamba Max 6900 and I couldn't gear it right with the stock 82 tooth spur so I went with an 86. My ESC gets about 190' and the motor is about 150'.
Jack
#154
ya so i put the rcommended novak fan on the fan mount on the motor and it just spun the fan completely out! all i did was solder it to a connector so that i can power it off of the reciever like my pt. any ideas of why and should i send it in?
#155
#156
I run a novak 6.5 and have an 88 spur with a 15 pinion. With brushless you should find the gear you like and go down one tooth.
#157
"I HIGHLY recommend to use TL or Luunsford titanium ball studs in the alum rear hubs"
My LHS guy said that too, so I'm getting the titanium ones. Hopefully this will cure my "3 broken studs in one night" problem. I'm sure it will.
As for a new owners of the CR Truck, I wouldn't even put those in, because when they break off, that spot is toast. Losi doesn't even offer these right now either, so you'de (me) better be carefull with the aluminum rear hubs.
#158
#160
Here's my first and only beef with this truck. When you buy additional wheels you have to buy the adapter and the screws separately. You have to buy the wheel bushing and hex set to get the adapter ..... losa3102, and you have to buy the screws in another package... losa6236.
#164
Does the older MF2 bodies fit the new longer chassis?
