Adding weight for Lipos >
Old 07-10-2007, 02:36 PM
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Default Adding weight for Lipos
What are you guys using to add the extra weight due to lite Lipos?
It's a huge difference and a lot of weight to add?
Whatever it is, I know it's gonna be big!
F N CUDA is offline
Old 07-10-2007, 02:48 PM
protc3's Avatar
in my 4wd it actually didnt hurt the car.in my 2wd buggy i am going to add the weight along the top of the cells and in tha back 2 corners of the chassis.rearward weight on the 2wd seems to work the best.more steering off power.
protc3 is offline
Old 07-10-2007, 02:53 PM
i run the maxamps 5000 and i added two ounces to the battery strap. this feels good to me. some people where i race add a whole strip to the battery strap which i think is like 3 or 4 ounces. we are also running indoors on very high bite clay so you might need to add more if your running outdoors.
Mauri is offline
Old 07-10-2007, 02:59 PM
protc3's Avatar
my maxamps 5500 saddle pack was 5oz. lighter than my standard nickel metal pack.i dont like losing that kinda weight off the rear of the car.in this case,it was a saddle pack on my 501x and it added a little on power steering.i went with a slightly different setup to get my off power steering back and now i add no weight to the car.the B4 is going to be a different story.
protc3 is offline
Old 07-10-2007, 03:18 PM
happywing's Avatar
Trader Rating: 93 (100%+)
I use this:
http://www2.towerhobbies.com/cgi-bin...?&I=LXCKT0&P=Z
happywing is offline
Old 07-10-2007, 03:27 PM
the 2 ounces i added to the battery strap was for my b4. forgot to mention that
Mauri is offline
Old 07-10-2007, 03:34 PM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I added 100 grams to my XXX-T.
The Xray weights are awesome.
You can thread them or servo tape them or shoe goo.
4300 I could control it, but get into the 5.5's and faster I needed the weight.
Couldn't keep the front end on the ground.
UN4RACING is offline
Old 07-10-2007, 04:01 PM
UN4RACING's Avatar
heres the Xray weights. Excellent.
Note the 5 gram ones behind the servo.
On the battery strap they are servo taped and tie wrapped.
The 5 gram ones are screwed threw the chassis.
Same on the nose.
100 grams total. Thats 20 on the nose,10 behind the servo and 60 on the battery strap.
Old 07-10-2007, 07:25 PM
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Default My thread in another forum
Peak GP3700
Peak 4800 LiPo
Max Amps 4400 LiPo
19T Peak Brushed
5.5 Peak Brushless
Reedy Neo 1* was 5.8oz
Novak 13.5 was 6.4oz (with sensor wire)
johnnyboy is offline
Old 07-10-2007, 10:04 PM
Mason's Avatar
which is more dense.. the lipo battery or the weights? high bite = put denser item lower. low bite = put denser item higher. polar moments/inertia can harm or help you depending on the situation.
Mason is offline
Old 07-11-2007, 08:26 AM
Tech Legend
Wild Cherry's Avatar
Default Ballast installation on Ae B-4
added ballast to equal a Gp3300 weight....
performance is awesome....
Wild Cherry is offline
Old 07-11-2007, 02:41 PM
Mark T's Avatar
Whats the weight difference between a 6000 and a IB 4200?
Mark T is offline
Old 07-11-2007, 05:30 PM
GymBeam's Avatar
what does a gp3300 pack weigh, with battery bars?
how much weight did you add to the orion3200??
GymBeam is offline
Old 07-11-2007, 09:38 PM
F N CUDA's Avatar
THANK YOU ALL!
F N CUDA is offline
Old 07-11-2007, 10:09 PM
Tech Legend
Can`t remember how much the 3300 Gp weighted...
I added a little more than 28 pieces at 5 gr each...
No weights added to the pack itself....
Have to tell you try this set-up ...
The car transfers weight smoother and has improved stability over jumps ....
Guarantee you after you try , you will never remove the ballast as I have it...
