Why do 2 wheels spin forward, 2 spin backward?
Hello,
Just put my Kyosho mp777 sp2 together. I put it on the starter box, and turn over the flywheel. The two back wheels spin forward, the two front wheels spin backward. What's happening? Do I have something put together backwards?
Thanks,
Bill
Thanks,
Bill
you have the front diff in backwards.
or you have the back diff in frontwards
Ok I can try that. But one more follow up question to that then - how come if I spin two wheels (front set or rear set) forward together just with my hands, the other set spin forward too? It's only when I turn over the fly wheel that I get the two fwd, two back thing.
I take it that means you've never heard of such a thing before...?
Could it have something to do with the polarity of the starter box? In a normal situation, should the flywheel be spinning clockwise or counter clockwise if you are looking at the car from the front?
When you have the car lifted up so all four tires are not on the ground, and then spin the wheels (front or rear) none of the diffs are in action. It's just like the car would be rolling naturally. Doesn't have anything to do with the starter box or anything else.
Because it's your front wheels that are spinning backwards, your front diff needs to be flipped around.
thanks! I'll give it a try.
Bill
Bill
Had a new guy at the track get his SP2 put together and engine broke in and he started it up and put it on the ground and it sat there and left black spots on the ground.
Most chassis' have a notch in them so you can't put them in backwards otherwise they bind. I'm pretty sure Kyosho's do.
I pulled the front diff off the chassis, and yes there is a notch in the chassis that the gear fits into. Is there something else I can flip around, because the gear cannot go any other way!
There is a notch in the rear of the chassis too for the rear diff. Can the center diff have something flipped in it to cause this?
To my amazement, I pulled off the rear diff, and the gear is on the wrong side (not fitting in the notch). It never was bound up though. Weird. So I'll get it flipped. But since the rear was spinning forward and the front backward, in addition I must have the polarity reversed on my starter box. Thanks for all the help.
Bill
Bill
