Electric 1/8th Scale conversion kits.
hi there folks, i gettin ready to build a brushless st-rr.and info would be great.was thinking about going with novak stuff.havent seen much on here about the new hv pro from novak.im scared of cc.heard to horror stories.or is their new stuff better.please help racin season is just around the corner.thanks...don
I will be converting a Losi 8ight T (the old version truggy; now that the new 2.0 is out) to brushless.
I will be buying the Losi brushless conversion, the Losi 14 tooth pinion and the Losi plastic 45 tooth spur gear. I also ordered a Zippy 5000 4S 25C pack from Hobby City. I am undecided on whether to buy the Castle Mamba Monster 2200kv combo or just the speedo and a Neu motor. I keep hearing the Neu motors are better than the Castle/Neu motors. Is this true and what is better and makes them worth the more expensive price? I need suggestions from the experienced people here. I will be racing and not bashing at all. Also, if I decide on a Neu motor, which one is recommended for racing and what do all the numbers mean after the motor part number such as 1515 and 1512? Also, any suggestions on where to buy the Neu motors online?
Thanks,
Ty
Thanks,
Ty
You wish list looks good. The Castle 2200 combo is good, but if you want the best get the Monster ESC and a Tekno Neu 1515/1Y check www.impaktrc.com for the motors and any thing eles you need.
Then come out to Medina this sumer.
Ernest is running 5-5-2 i believe and he likes it. Can't really do much to improve steering under braking. Can't turn if you tires are locked. This is when mech brakes would help. 1 or 2 for your higher ratio rc8. 189 would put you at 38mph and 20 would be at 40mph. Don't really need much then that. The pit runs 20min A main so battery life would be a concern for you. 6 min quals should be no problem. Brad, Ernest and I have no problem running 20min main with our 6S setup.
Im gonna drive up again on sat and come race. I dunno if there will be a big crowd with the NC and all but o well.
Ray have you temped your motor at all after putting a pack through it at 18/46. I want to know what it was. I am still working on gearing mine correctly and dialing it in.
thanks for the link.but all i could find was a motor mount for the kyosho.i'll do some more searching.how many problems have you have with the mamba system?
Try ABS on the transmitter. That might help. I am thinking of trying a really fast abs speed with a mild delay.
I temp motor/speedo after main last nite 123 motor and 113 on speedo.
Not sure track will be open. they might be getting ready for cactus. And of course, all the nitro guys will be at the pit for NC.
I came off at like 170 for motor and 125 for esc. Pretty warm. Just with the stock 8ight-e body and no fan on esc because it broke. I'm not sure where to go at this point with gearing. I think down, but some people say up and I cant go down because I need the speed.
