MANIFOLD GASKITS!!!!!!!
engines are meant to work when everything is sealed, and if a certain area is compromised, then yes it very well can cause an engine to act up.
As for the pivot, I don't think losi makes a graphite pivot for a gas truck, if that is what you are talking about. Pivots break, stock up on them, that is the best you can do!
I just bought a graphite rear pivot block for it!!!!
And I was wondering if it would cause it to have less top end power and stalling!
yes as you found they do make graphite pivots blocks. and yes a damaged gasket or loose bolts would cause those type of issues with your motor.
Forget the gasket. Just use automotive silicone.
