MANIFOLD GASKITS!!!!!!! >
Old 04-08-2007, 07:31 PM
LOWGEARED's Avatar
Angry MANIFOLD GASKITS!!!!!!!
Can a damaged manifold gasket cause the engine to act up?
Also I just cracked the rear pivot block on my LOSI is the graphite pivot a better piece?
LOWGEARED is offline
Old 04-08-2007, 08:02 PM
Trader Rating: 14 (100%+)
engines are meant to work when everything is sealed, and if a certain area is compromised, then yes it very well can cause an engine to act up.
As for the pivot, I don't think losi makes a graphite pivot for a gas truck, if that is what you are talking about. Pivots break, stock up on them, that is the best you can do!
o.s. power is offline
Old 04-08-2007, 08:06 PM
LOWGEARED's Avatar
I just bought a graphite rear pivot block for it!!!!
And I was wondering if it would cause it to have less top end power and stalling!
Old 04-08-2007, 09:06 PM
AzBobby's Avatar
yes as you found they do make graphite pivots blocks. and yes a damaged gasket or loose bolts would cause those type of issues with your motor.
AzBobby is offline
Old 04-08-2007, 09:09 PM
secretsg's Avatar
Forget the gasket. Just use automotive silicone.
secretsg is offline
