New idea of Suspension system
#17
I think the HPI Baja uses a two spring setup like this.
#18
The overall goal of the system would be to run a setup that will allow you to take big jumps w/out bottoming out hard or having so much spring that the car bounces. This allows you to run a thinner oil which will result in a more responsive car that takes bumps easier.
#19
#20
no the weight shouldnt be a problem, as my dad gets these high power magnets from computer hard drives, and theyre about an inch across, and if i decided to put my finger between two it would take it off! and if i wanted to change damping strength i would use electromagnets powered off the receiver pack, or on an electric like im gonna build off the nimh battery pack.
#21
speaking of magnets, hey those hard drive magnets are the ones i've been using to keeps my bolts, screws, washers, e-clips, etc in one place when i dismantle or repair my buggies. They are indeed strong magnets! if weight is no object then your idea is great. What i was thinking is combine the power of magnets and Airtight shock cylinders. Yes - air! the conbination of magnet and air would give a great damping strength. what do you think?
#22
I would like to see a suspension system that accurately duplicates that of 1:1 baja buggies. I've seen bypass shocks and progressive rate rockers.
Kinda like the Revo but not inboard. The shocks themselves could be vertical and closer to the centerline of the vehicle.
#23
don't we all. a guess is two things as to why we don't see that set-up. one is weight for electric especially. and two they would be much more complicated to assemble that some might not be able to do it. and there are alot of kids in this hobby, that type of shock would really confuse them i think. that is if the internals are actually as they are in like King or Fox shocks used in off road race cars. just a guess though.
#24
what about just a huge airtight cylinder? air suspension
#25
Got a video to share. this buggy has a dual rate installed. (the zaint mod not the ready made)
just don't expect too much
http://www.rcuvideos.com/item/WMVX7GXSX781B71C
