HELP!!
HELP!!
my dtx .18 engine wont run good at all. it can strat but as soon as i take th glow starter off the glow plug , my ingine dies help!!
sory about the spelling
i just got a new one
if the tuning on your motor is way off it will eat a new glow plug quickly. put in a new one and try to retune. also check to see if you have an air leak in your fuel line, pressure line, check the o ring on the gas tank under the lid, and check that you carb area is not sucking air. by way of a crack in it, also make sure your head is on tight no loose bolts.
