Spy Photos: Losi mid-engine 2wd
#16
A battery mounted across the chassis will not make for very good polar movement..I understand there's not much room in the chassis, but it's always good to have the weight towards the center of the car.
mafia - If the car turns out to be pretty good, I'm sure there will be enough different to offer a completely new kit. At the very least, the rear end will need a ton of new parts and if the car is going to need a LOT to convert an older kit, I'm sure it would be more economical for the company and the consumer to have a completely different kit.
#17
nice
#18
I'd guess after a discreet email or two from TL we won't hear much more about this particular project again.
I'm not sure if this concept can be proven without a few of the best drivers in the world behind the wheel. It was tried in the 80's and worked great in oval, i'd guess it may also be good on grass?
Origional, no, anything to do with TL, no, Cool.....well ya!
LOL, Jim
LOL, Jim
#20
It's very possible it's just an engineering exercise. That kind of stuff happens all the time.
#22
I got a kick out of getting home from the race in Vegas this past weekend and seeing this thread...I just heard about this car over the weekend, get home and there's pictures of it on the internet!
Like I said...companies try stuff all the time. The advent of the (good) digital camera, and the internet, makes it easier to catch prototype stuff and show it to the public.
#23
well, the body looks to be right off a xx-4, so odds are thats the basis for the chais. Now, lets go and shave out that slot for the belt and sit the batteries right there. Now, lets go and mount up that xxx trans in the back of the car and mount the xxx front end on the front. Now if you are seriously clue less as to how to reverse the gear box then maybe you should switch the polarity of the motor. Yes, they will spin both directions at the same speed if setup correctly. As far as the positioning of the electronics and batteries heres a simple concept to think about. The closer it is towards the center, the faster it will shift its weight. This means that when you give it throtle it will send weight to the back faster and ect. If you sit the batteries on the sides then the car will roll slower. Ever stood in a canoe? Close your legs and you will notice what little changes do and how fast it moves. Spread them and you will notice how much slower things change. It all comes down to how fast you want the car to roll. I am sure that you can run softer shocks in the rear end to create the needed tractioin for 2wd. This means that the car can turn sooner after you aply breaks and get heavey on the throtle sooner after you come out of a corner. If you are familiar with 2wd you will know that when you come out of a stand still or off the breaks the car will not accelerate well at all. However, once that weight has shifted the car can be pushed very hard if set up well. When you move weight from the rear to the middle, this also allows you to move extra weight from the front to the middle of the chasis which will help to send weight back to the rear when you get on power. Now, what this means is that you can now break for less time when entering a corner. Then when you exit the corner you can now baby the throtle for less time as you exit the corner.
#24
I donno if I agree with all of that, but it's definitely nice to see the Losi guys (even if it is not factory-authorized) continuously trying to get faster. I still think that regardless of the success or failure of the 4wd car they ran at the worlds, you have to give this team props for trying new (and old) things.
I'm looking forward to seeing photos of this car without the body on it.
doug
doug
#25
We may or may not see pictures without the body, who knows?
I certainly think it's more involved than taking a XX-4 and pulling the front drive out of it, factory authorized or not. Losi is very well known for trying a lot of stuff to learn what changes everything makes.
#27
the 2 cars that are the main focus of this thread are Identical afaik steve and both use a narrow chassis. its just one uses a narrow shell as well.
