Compatibility and which to choose
Can someone tell me if this would work in my Arrma Senton 3s? Also any suggestions on whether to go for the 3150kv motor or 3700kv motor?
Here is the stock 3s motor https://jennysrc.com/products/arrma-...irma-ara4302v3
But you could probably use either kv's
Motors are simple and cheap (for 3s bashing anyway). If you don't overheat it or mess up the bearings, a brushless motor will last forever.
Get the 3200 KV.
Get the 3200 KV.
They're motors. If you're a basher, they'll be fine. I've had a couple of cheap 3660 Rocket/Surpass motors for 30-40 bucks from China and they were all fine. ESCs are another matter...
cheap or mismatched ESC's specs to motors are usually what cause people problems. You put a 4s motor on a 2s ESC and yeah, you may have some problems.
Just to be clear, are you talking to nino or about the motor I originally posted? The motor I showed is a 3s motor, and my stock esc is 3s. So unless you’re talking to nino, not sure how what you said applies.
