Schumacher cougar LD3
#34
R/C Tech Elite Member
On a smaller track I've run 29/71, the trans ratio is 2.53:1 so you can compare it to B6.4 (2.6:1) and TLR 22 5.0 (2.43:1) and figure out pinion size from there. I don't believe anyone uses other brand spurs, the spurs ride on a bearing and the slipper shaft is bigger than TLR and AE spurs.
#36
#37
#38
Got my LD3M all built. My first ever schumacher car. It's a nice car to build. But definitely different from a TLR I'm used to. Few things I dislike, but knew going into it. Wished it used traditional shock stand offs and screws to hold the rear shock at the bottom. The front and rear hex I definitely dislike with a o ring holding the pin in place. Having to drill the bleeder screw. Shock springs are jind of odd how they go from narrow to wide. I see Cav runs AE springs, what spring cups is he using?Now these are probably all no issue just different. My track has zero parts for the car so I will have to order everything. How durable are these cars? I know everything can break obviously, I'm not a rookie and don't crash often but still do crash some.
#40
I have to agree with you though, having to drill the shock caps is just silly and o-rings for the hexes...really? lol And while I was running the shock tower in front of the shocks on my LD2 it took a decent hit to the front and one shock cap popped off the ball stud. It was a quick fix but my B6.4 would've just shaken it off. So far I haven't broken anything on either car but a front arm on the 4whl, totally my fault though. On carpet I've heard the lower front plate can crack on really hard front hits but carpet is hard on everything.
#41
does anybody know what parts you need to get the topshaft from the LD3 to fit on the LD/LD2 car ? do i only need the new topshaft or do i need the slipper as well ?
#42
what does that 4wd weigh with that carbon chassis?
#43
The LD2 is quite built well, it has taken a good beating by me, the only this I would stock as spares are front arms, spring seals (get the on road blue ones) and ball cups. Schumacher ball cups do not last that long. If you are running a ball diff, you will have to rebuild it more frequently than TLR or AE.
#44
@ fa7boyrc:You will need:
U8620 Alloy Layshaft - LD3
U8621 Layshaft Bolt - LD3
U8399 Outer Slipper Plate - L1R
U8631 Outer Slipper Plate - LD3
I am one of those who don't run aeration I prefere bladder.
For the shock bottoms in the reaer there are options. You can also run the combination of U8428 5.5mmball and U7431 Or if you want a screw:U7367
O-Ring on hex never was a problem .
There will of course a pictured build in the next week.Just be patient.
Cruise
Cruise
