Mugen 2WD Buggy!!
#31
I know it has nothing with this buggy and its been like this for like a decade or more now but I HATE the current offroad layout with battery in the middle and ESC in the front. the motor wires should be kept short not run all the way along the long axis of the chassis IMO. just bad engineering. but since everyone is doing it I guess that's just the only way it can be done.
#32
Which is why the mugen is a rip off of the TLR front cosmetically and the AE geometry wise and quick access diff wise. Why innovate when copying is good enough?
#33
Look at the TLR 22 5.0 manual for an example of how that mount works. It is very durable.
#34
#37
#38
[Yeah, cause that wire has tons of resistance. ]
It's a non issue. Besides, it's the lamest class in all of rc racing. I doubt there's going to be a heat issue with the wires.
#39
FWIW, most buggy manufacturers have likely stuck with the laydown, mid-motor and centralized battery, because they have been able to get them working at least as good or better than other configurations across a wider variety of track conditions… So you either make a buggy that can be reconfigured all sorts of ways, or you can stick to one configuration and our enough adjustability to work in a variety of conditions. From a cost effective perspective, you can see why they went for the latter route.
Personally, I like the modern layout. Everything of weight is in-board and more or less centralized. It’s no surprise that a lot of buggies look similar… and it’s not much different in the Touring Car class either. All those cars are so familiar, outside of the Awesomatix - with an honorable mention to Serpent’s Project 4X from about 5 years back.
#40
[QUOTE=Zerodefect;16035507][Yeah, cause that wire has tons of resistance. ]
It's a non issue. Besides, it's the lamest class in all of rc racing. I doubt there's going to be a heat issue with the wires.[/QUO
#42
Yeah, I think it's a pretty big improvement on high traction to have the heaviest component (battery) basically right at the centrepoint of the buggy, this has been ongoing for the past few years. Only question to me is if they will start moving the motor forward too.
#43
A while back someone smart explained the dynamics of he motor’s torque/leverage over the chassis & weight transfer to me that I’d never considered. It was pertinent to the difference between the way AE’s two mid motor transmissions behave. I won’t try to recall it, I’d just confuse myself (and probably readers here) but the explanation made sense out of motor position on the chassis unrelated to front/rear weight bias. It led me to believe that they”ve found pretty much the optimum position. There is that conversion that stacks idler gears to move the motor WAY forward but I never heard of one running remarkably well.
#44
#45
When does it come out?
Anyone know release date?
