Tekno SCT410SL
#106
The wheels are JConcepts Hazard 3356Y +3 offset , and the tires are Proline Prism Fronts . I threw these on because I ran the truck on the indoor carpet and happened to have an extra set from my 2wd SC6.1 , I did not want to wear down my 4 newer Prisms I run on the turf ( in my video ) . For the turf I run Prisms all around .
#107
#108
Sorry , no video , but drove the truck again yesterday on the same turf layout as in my video , with the new 6400 mah 140c short pack and now a 18t vs. the 17t I had on it . Also layed the rear shocks all the way down , truck drove even better !!! Faster on the straight , and I hate to say it , might try a 19t pinion !!!! As it stands , this truck is very dialed in on turf right now !!!
#109
The 4WD SCT is very popular in Western Australia, a few weeks ago we had 16 at a Friday night race meeting, they are awesome fun 👍
#111
I forgot to mention my issue with hood louvers. Body mounts probably will not be an issue for most bodies, but mine was an older JConcepts Raptor.
Body pins needed more room than the molded-in hood louvers would allow. Well, I didn't think reversing the front body mount was possible, but turns out the molding on both sides of the mount fit on to the shock tower, and will move the posts back about 9.75mm from stock position. Perfect!
#113
What's your issue with STRC?
#114
other than 3d printing one, anyone have a recommendation for a receiver box on the sct410sl? not sure if any of the Tekno ones available will fit.
#116
I think you're looking for a receiver tray similar to this:
https://www.amainhobbies.com/tekno-r...r7299c/p866339
This would be a transmitter case as an example:
https://www.amainhobbies.com/protek-...k-8160/p228958
#117
Sorry, brain fart - I'm looking at receiver box solutions. The track I go to is pretty dusty. I was looking for something like this - https://www.teknorc.com/shop/tkr4500...v3-v4-chassis/, but the dimensions aren't posted, and I'm worried it could get in the way of the servo link.
#118
Not aware of any enclosed Rx Box for their 1/10 kits, but wouldn't be surprised if could get a waterproof Rx box from any 1/10 RTR brand to fit with minimal mods.
Good Luck!
#119
Pretty sure that's for a 1/8 nitro buggy to electric conversion which is what TEKNO had specialized in before they introduced their very first kit.
Good Luck!
Good Luck!
#120
sawzall, I do not know of any sealed receiver boxes designed for the 410 platforms. The closest thing to what you are looking for would be the Raceform EB410/ET410 tray, but I don't know that it would be large enough for some of the ESCs people use on their SL builds.
There are some that have used an Axial receiver box (mounted to rear of chassis)
Some will use "custom" 3D printed generic boxes. I found one receiver box STL file online that was 2x7mm and just scaled it up... will definitely have to make it bigger next time around...
