Mod Racing - Motor Selection - Transmitter Settings >
Like Tree8Likes
  • 2 Post By brian mills
  • 1 Post By Alexv2024
  • 1 Post By Cromulent
  • 1 Post By Pistol123
  • 1 Post By DirkW
  • 2 Post By Alexv2024
Old 12-06-2021, 08:56 PM
Default Mod Racing - Motor Selection - Transmitter Settings
For mod racing, it seems I always see questions regarding what motor people should run. Why not just go with the lowest turn like a 4.5 or 5.5 and just use EPA and EXPO to tune it down to where the user is comfortable? Would that make more sense rather than investing in different turn motors? I've never used it, but I know some transmitters have a feature called Punch that you can adjust as well.
Wouldn't using transmitter tuning be more affordable as well for most racers?
silence360 is offline
Old 12-06-2021, 10:08 PM
I feel that it is always best to use the most appropriate wind and rotor for the application. When you use epa to limit the top speed the throttle curve is effected. Expo also makes a non linear feel through the curve as well
Kraig and RogerM like this.
brian mills is offline
Old 12-06-2021, 10:42 PM
Alexv2024's Avatar
Mod makes all the settings that change how the car behaves useful, to an extent.
For say 2wd mod on dirt, you don't really need to go below a 6.5, most people run a 7.5. Most people run a 6.5 or 5.5 in 4wd on dirt. Take a turn off for carpet.
But yes after that, rotor tuning is important. Then depending on grip level I'll run 90-100% epa/dual rate on the throttle to change power to how well I can use it.
Example when I was learning a layout and changing between practice tires and stuff, I had my 4wd mod down to 80%. Then after getting tires right, and learning the layout I was able to use 95-100% of the motor after that.
Frequency, punch, dead band, slipper settings, and other stuff. Everything becomes more critical in mod since you have 30-50% more power.
I run on dirt so I have a 7.0 in my 2w and I have a 6.5 for my 4w going to get a 6.0 soon. And I tune D/R and epa to tailor power to the layout and other factors. But don't go crazy low turn way beyond your skill. Its not needed. Running the motor turned down will help it last a long time though especially compared to stock.
RogerM likes this.
Alexv2024 is offline
Old 12-07-2021, 10:54 AM
Originally Posted by Alexv2024
...And I tune D/R and epa to tailor power to the layout and other factors...
Why use D/R? That'll bring the EPA for both throttle and brake down together. Just because it's easier to access on the fly?
brian mills likes this.
Cromulent is offline
Old 12-07-2021, 04:50 PM
I really like the feedback I'm getting, this is quite informative, thanks to everyone who has commented.
I found this site that explains settings pretty well for those interested who are not experts of tuning throttle.
https://www.trackstarrc.net/blogs/ne...itter-throttle
Old 12-07-2021, 08:18 PM
Alexv2024's Avatar
Don't use trim/sub trim for drag brake tuning unless you're on track and its just so broken you can't do your qualifier.
It wont let the esc go to neutral and might have issues turning on. Most escs need to see the radio in neutral to fully arm and be ready to race.
Plus its a super coarse adjustment compared to changing the esc settings.
Old 12-08-2021, 08:19 AM
A guy I race with does that for dirt oval. He's running a 4.5t w the EPA turned down to suit. It takes motor selection out of the equation for a bit.
--Alex
alexo35 is offline
Old 12-08-2021, 10:47 AM
DirkW's Avatar
Not necessarily so. At least my radio has separate D/R for throttle and brake, only steering does left and right equally.
DirkW is offline
Old 12-08-2021, 11:35 AM
Odd, I thought that was the "dual" in dual rate. How does that differ from EPA?
Old 12-08-2021, 11:53 AM
DirkW's Avatar
Not much difference for throttle. D/R settings are easier to adjust quickly and settings are visible on default screen.
DirkW is offline
Old 12-08-2021, 12:28 PM
Pistol123's Avatar
My understanding is the EPA is set then you can't go beyond that point to protect the servo, then you use the dual rate to adjust as the conditions require knowing you cant go beyond the end point and damage anything.
On Sunday we raced on a damp/wet slippery astro track, I managed my fastest lap in the first round of qualifying and my car just wasn't right, no really power or punch and when I crashed it would then go. Turns out that one of my motor wires was only just connected, I will be turning everything down in future as I didn't go any quicker when I was vack up to full power. Every day is a school day.
ray4624 likes this.
Pistol123 is offline
Old 12-08-2021, 01:04 PM
DirkW's Avatar
That is true for a servo (i.e. steering), but usually you calibrate the ESC to the radio for throttle, so EPA can stay at 100%.
Pistol123 likes this.
DirkW is offline
Old 12-09-2021, 08:22 AM
do you know if you have to set the throttle and brake dualrates back to 100 when re-calibrating an esc?
i do anyways but it would be nice to not have to
ray4624 is offline
Old 12-09-2021, 09:20 AM
Alexv2024's Avatar
Whenever you're setting up an ESC you want DR EPA all at 100% and no expo or curve or anything like that. The ESC gets the signal from the radio and doesn't know its changed in anyway.
RazorRC and ray4624 like this.
